cheap lifts?
Old Dec 3, 2010 | 01:11 PM
  #76
TexasGuy001's Avatar
TexasGuy001
Yes they are. For the purpose you are using one for, I can see it being helpful though. There are ill effects. It throws the fitment of other components out of whack.
Old Dec 3, 2010 | 01:58 PM
  #77
nobearsyet's Avatar
nobearsyet
No, if you buy a kit, not stack gockey pucks or the like, and you reshim your body panels like you're supposed to the nthere is no downside to a body lift other than it doesn't net you any more suspension travel. I've installed lots of them, that was what I did for a living for a while. I worked at a 4wd shop and we sold a bunch of them.
Old Dec 3, 2010 | 04:24 PM
  #78
Samsonitesamsonite's Avatar
Samsonitesamsonite
No. A BL raises your COG, is hard on linkages, increases body roll. I personally have seen what happens when the body mount bolts break becuase they cannot take the side loads exerted on them. The amount of leverage on a bolt with a 3" BL is incredible. Just do it right the first ti
e. I installed a couple as well back in highschool, because they're cheap. Does that mean that everyone who installs a BL will have a failure? No, the vast majority will be fine. But they are just not a good idea. Period. I, for one, would not want to take the chance, especially if family is going to be riding with me.
With that said. a 1" body lift is understandable if you are doing a tummy tuck on an offroad rig, or you need the space for a bigger engine/trans combo. The amount of side loads on a 1" is 1/3 that of a 3". And I could even see a 3" if it was astrictly a mud/offroad truck, no highway speeds or fast cornering. But for a DD? No.
Just don't do it.
Old Dec 3, 2010 | 07:05 PM
  #79
6CylBill's Avatar
6CylBill
I agree. But I will say this; A suspension lift raises the center of gravity also, and more so at that. A body lift won't raise your center of gravity near as much.
Old Dec 3, 2010 | 10:41 PM
  #80
Samsonitesamsonite
yes and no, the increased body roll of a BL greatly accentuates the increased COG, so even though the COG on a 3" body lift is lower than that of a suspension lift, the body roll makes the body lift much more dangerous.
Old Dec 4, 2010 | 12:22 PM
  #81
6CylBill's Avatar
6CylBill
Good point, I didn't think about that.
BTW, I have a 3'' body lift on my poor baby. Wish I'd never done it.
Old Dec 5, 2010 | 11:01 PM
  #82
dsands88's Avatar
dsands88
Can any one point me in the right direction of a bl with bumper brackets?
Old Dec 5, 2010 | 11:44 PM
  #83
nobearsyet's Avatar
nobearsyet
Performance accessories kits usually have the brackets in them.
Old Dec 6, 2010 | 10:15 AM
  #84
L. Ward's Avatar
L. Ward
1987-1991 Ford F150 2wd & 4wd - 3" Body Lift Kit
Product Part #:
763
Product Brand:
Performance Accessories
Body Lift Kit Tech Notes:
5. It may be necessary to drill the front two body bushing sleeves out to 1/2" for new bolt clearance.
11. Vehicles equipped with 6 cyl or V-6 will require replacement of lower radiator hose to avoid contact with smog pump.
14. Will not fit vehicle equipped with diesel engine.
26. No bumper brackets are included
The problem you are going to run into is the way the frame horns extend into the bumper, you are pretty much going to have to make your own and notch the bottom of the bumper or the frame to let it raise up 3" or else accept that it is going to look like this
Now, since you evidently want to ignore those of use who have already been there/done that and ended up
And, since you seem determined try and throw on this
So you can put on these
Without addressing this
or this
or this
While trying to make a 185hp 302 with this
this
and this
power something like this
and seem to be determined to do this
May I suggest on the front and back frame rails mounting some of these
or these
Preferably like this
So when the stock 302 can't spin the tires enough to keep moving and ends up like this
Someone who actually geared and setup a truck correctly can hook up and do this
Oh, and when you end up stuck, DO NOT use one of these
Unless you want your hood or tailgate to look like this
Old Dec 6, 2010 | 10:47 AM
  #85
BearFootCustom's Avatar
BearFootCustom
That was good haha
Old Dec 6, 2010 | 10:53 AM
  #86
frederic's Avatar
frederic
Thank you for the laugh L.Ward
Old Dec 6, 2010 | 01:35 PM
  #87
Vacationtime247's Avatar
Vacationtime247
Damn I just love how the big older Bronco's look. Only had 1 and man that thing plowed through snow like a champ! Only gave $400 for a derilict 88' Bronco with a 351W. Judging by the paint sheme I think it was an old park ranger / conservation officer Bronco. That looks like sooo much fun below!
VT247
Originally Posted by L. Ward
Dropping the transfer case into "low range" doesn't count
Same pit with a much better cam and carb'd 460 in a 78 Bronco with 38's and 3.50's?
Just sayin....
Old Dec 6, 2010 | 03:41 PM
  #88
Samsonitesamsonite
LMFAO .
Old Dec 6, 2010 | 07:34 PM
  #89
cowman435's Avatar
cowman435
i agree stay away from body lifts i have one on my truck got it that way and its not worth it im in the process (thought process) of removing mine and for alot of stuff you dont really need 35's but that is just my 2 cents. good luck to you
Old Dec 7, 2010 | 12:41 AM
  #90
TexasGuy001
Even if you buy a kit you still have to deal with the fan shroud, the shifter linkage, the bumpers, possibly brake lines. Besides that you can see the frame and exhaust hanging low not to mention the gap between the bed and the frame at the rear wheels. Its just a poor way to lift a truck.
