Making a D50 TTB into a solid axle?
Old Nov 23, 2010 | 07:00 AM
mechelement's Avatar
mechelement
The D50 differential has an external oil seal on one side of the pumpkin and that bearing w/ seal on the other. Both are uninstalled by pulling them OUT of the differential... Are you going to weld onto the differential? How will you service your seals and bearing?
Old Nov 23, 2010 | 05:03 PM
Otahyoni's Avatar
Otahyoni
Thats why Oreo suggested bolting the two halves together, for replacement or service...
Old Nov 23, 2010 | 05:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
oh man.why would you want to ruin a nice riding axle.
you guys want the ride of dump trucks,and iv got mine setup to ride like a caddy (well ok,maybe not.but no firmer than stock. ) LOL.
my diesel chipper even has independent suspension.
http://www.salsco.com/products/86_Series_WEB.pdf
she rides and tows GREAT compared to the straight axle ones.i know cus iv rented plenty before buying (now with the duals i hardly know its even there.sweet setup!)
independent suspension is a good thing guys.
less you like to ware your coffee instead of drinking it.
it is interesting how differently we all use our trucks.
one guys setup can be pointless or outright horrible for another guys use.
oh yeah,i just remembered this.
some of you guys will like this thread:
https://www.ford-trucks.com/forums/1...b-rebuild.html
Old Nov 23, 2010 | 06:21 PM
catfish101's Avatar
catfish101
Not all the TTB50's evidently are the same. I only have one that is out of a 95 and another one that is out of an 87 or 88. They aren't the same other then design.
Old Nov 23, 2010 | 06:39 PM
mechelement
It would be weak. Just yank a SFA Dana 50 out of a puked F250 PSD if you want a SFA Dana 50.
Old Nov 23, 2010 | 09:01 PM
Dodge/Cummins's Avatar
Dodge/Cummins
It'll have a metric 8 on 170mm bolt pattern then.
Old Nov 24, 2010 | 07:51 AM
mechelement
Good call.
Old Nov 24, 2010 | 08:23 PM
93Fodge's Avatar
93Fodge
Take the unit bearings & rotors, and have them redrilled to 8 on 6.5". A good machinist can have them both drilled in about an hour, and shouldn't set you back too much
Old Nov 24, 2010 | 11:49 PM
Country_boy_2007's Avatar
Country_boy_2007
ill take my 60. honestly it dosent ride that much harder than it did with the ttb, and i got an add a leaf it it. the solid axle is tried and true, and you cant get any stronger than a solid axle. it all depends on how you use it. plenty of people will never break a 50 ttb, if ya dont mind jacked up camber, or replaceing those damn bushings and ball joints.
Old Nov 25, 2010 | 09:46 AM
Dodge/Cummins
I don't "like" TTB but I've only had one truck with it and it was trouble free. It was a '97 D50 TTB that I later swapped for a '90 D44 TTB to change the gear ratio. I don't think it rode any better but I'm not known for complaining about ride quality unless it is really bad.
I kind of like a "stiff" ride that stays off of the bump stops. I actually hate the ride of a lot of cushy 1/2 tons. I prefer stability to a soft ride.
Old Nov 25, 2010 | 04:21 PM
IDIDieselJohn's Avatar
IDIDieselJohn
A good reason i could see for this is to reduce, or eliminate the 'one-sided tire wear' that is so common with the TTB axle, with less cost than a D44/D60 swap...
That's why it's important to do tire rotations on these trucks....
My '90 F250 with a D44HD had a bad case of that one sided tire wear.
Always the passenger side tire, would wear out starting from the center of the tread, going out. Other half of the tire was always fine.
Old Jan 2, 2011 | 01:23 PM
americanmadegoodness's Avatar
No oreo, your not alone on being over 6"
Sitting on 9" 6" suspension with 3" body.
justcruzin125
Nov 9, 2016 10:48 AM
Jasona7227
Jun 17, 2015 07:39 PM
Thor'sHammer
17
Nov 14, 2014 07:31 PM
NotPossible907
Jun 2, 2014 11:58 AM
pengintamer
25
Mar 17, 2012 08:16 PM
