Making a D50 TTB into a solid axle?
Old Nov 22, 2010 | 09:54 PM
johnboggs21's Avatar
johnboggs21
Hows this sound for an idea. Would it be possible to lock the two halves of a TTB axle together with some sort of bracketry? Almost like boxing it in. I believe the D50 has the same heavy internals of a D60, right?
Old Nov 22, 2010 | 09:55 PM
johnboggs21
Also, if this turns out to be a good idea id like first credit for it LOL
Old Nov 22, 2010 | 09:56 PM
Otahyoni's Avatar
Otahyoni
I help think this up!
And i've got a complete spare D44 to play with.... so lets get some brainstorming going...
Old Nov 22, 2010 | 10:00 PM
rodneywar's Avatar
rodneywar
the d60 internals are stronger than the d50 but i dont see why you cant box it up and weld the **** outta it
Old Nov 22, 2010 | 10:04 PM
93Fodge's Avatar
93Fodge
It's already been done. Go check out Pirate 4x4 in the ford section. Run a search for D50 solid axle. I also recall reading a build where someone cut the ends off a D50TTB, welded them onto the carrier from a rear 60 and built a custom D60 that way.
When you get to the strengths & weaknesses, for the amount of work you'd invest, the gains are minimal at best. The D50 has an odd ball sized ring & pinion, and isn't much stronger than a D44. The outers are D60 outers, but you're still stuck with D44 sized inner shafts.
If you just have to have a solid D50, go pull one out of a 99-03 F250 Stupor Duty. Its already set up for leaf springs, and has much better brakes.
Old Nov 22, 2010 | 10:07 PM
starmilt's Avatar
starmilt
I guess you could weld up the housing to make it ride like a D60, but that is all you would be accomplishing,as you still would have the weaker axle setup of the 50.
Old Nov 22, 2010 | 10:15 PM
oreocreaming's Avatar
oreocreaming
hes already got a d50. you guys act like hes swapping out a rockwell for a toyota axle lol. hes keeping the same thing, just making it straight. other then lifting it, im not sure why you'd wanna do it though. doesnt ride any smoother, you already have leaf springs, same gear options you have now. and you dont wanna weld, you wanna do a bracket. that way if something happens to one side, its not a total loss.
Old Nov 22, 2010 | 10:19 PM
starmilt's Avatar
starmilt
Oreo that is why I said all he would accomplish is to make the ride like a 60. Why would you want a little harsher ride with absolutely no gains. (unless you were wanting to lift it)
Old Nov 22, 2010 | 10:23 PM
johnboggs21
shoot fellas i aint got a D50 lol. Just an idea that floated across my head while chattin with chris lol
Old Nov 22, 2010 | 10:27 PM
oreocreaming
and i think you would need at least a 6" lift on it with some lowered bump stops to stop the peak of the axle ends from hitting the center section. and it would look like crap.
Old Nov 22, 2010 | 11:16 PM
Country_boy_2007's Avatar
Country_boy_2007
yea a 50 ttb really isnt any better than a 44. same hubs, outers, smaller shafts, more ujoints. id just find a 60. i just did the swap, it went real smooth for me and yay...no more balljoints and wacked out camber for me.
Old Nov 22, 2010 | 11:40 PM
mechelement's Avatar
mechelement
Wouldn't changing the seals on the sides of the differential be a royal PITA if you did that?
Old Nov 23, 2010 | 02:46 AM
rolape2's Avatar
rolape2
The additional lift this would allow over what is available for the TTB would only be usefull for tires the would be to large for the small inner axle shafts to handle in situations that you would want it raised for anyway.
Old Nov 23, 2010 | 06:47 AM
Otahyoni's Avatar
Otahyoni
A good reason i could see for this is to reduce, or eliminate the 'one-sided tire wear' that is so common with the TTB axle, with less cost than a D44/D60 swap...
Old Nov 23, 2010 | 06:58 AM
oreocreaming
you can get a 6" drop bracket for the ttb. I don't see anyone here but my dumb *** lifting over 6" suspension
