Sponsored by: Auxito
starter cranks engine wont start
Old Nov 22, 2010 | 06:08 PM
foldm's Avatar
foldm
If anyone can help that would be great
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
F150 2000 4.6 4X4 117,000miles
<o></o>
Started the truck 3 times in the morning then drove 1.5 hours stopped for gas. Got back in the truck; tried to start it and starter cranks, engine doesn’t catch. Tried it multiple times same thing. Turned the key to power waited then tuned it to ignition and still the same problem. Got it towed to the shop, set the truck down and it started right up (turned it off and on a couple of times started up every time). Over the weekend the same issue came up multiple times. When it wouldn’t start I would have to turn it to power wait a little while then hit the ignition, it would start. First start in a while it would start up fine is would be the quick on/ off intervals (10 mins) it would have issues.
<o></o>
- spark plugs and wires are fine
- (when It wont start) I checked the Schrader valve on the fuel line it bubbles up fuel out of the lines
- When It wont start banged on the bottom of the fuel tank to see it the fuel pump was sticking, doesn’t help
- Doesn’t have a problem when started
- (when It wont start) starter cranks over solidly
Old Nov 23, 2010 | 06:12 PM
enriched&beyound's Avatar
enriched&beyound
fficeffice" /><o>></o>>
<o>></o>>
<o>></o>>
take it the starter is turning the engine over fine? Or Is this a starter engagement problem?
it would then seem that your haveing a spark issue, or spark loss issue.
when this is not starting...can you (with some help) have one turn the engine over and give a whiff of starting fluid in the air intake. if it acts like it going to start or run briefly then it is a fuel delivery issue...if not then it confirms a spark loss.
in the mean time check any and all grounds make sure that they are all good
Old Nov 24, 2010 | 05:54 AM
Joe Finn's Avatar
Joe Finn
The next time it does it, try pressing the gas pedal slightly. If it starts, it means your IAC is bad.
Old Nov 24, 2010 | 12:03 PM
foldm's Avatar
foldm
tried the gas pedal during start and that didnt help
Old Nov 24, 2010 | 12:19 PM
foldm's Avatar
foldm
the starter turns over the engine. dont think its a starter issue. think my fuel pump is going out but im not sure.
Old Nov 24, 2010 | 03:22 PM
KingRanchMan02's Avatar
KingRanchMan02
Is the "theft" light flashing when it won't start?
Old Nov 24, 2010 | 09:09 PM
foldm's Avatar
foldm
not its not flashing when the truck isnt starting
Old Nov 25, 2010 | 12:20 AM
chass1971's Avatar
chass1971
my truck is doing the same thing every morning, I own a 4.6 98, now the only way it starts in the is if leave the key on the ON position for 10 seconds then crank it. the fuel pressure is around 40 psi
Old Nov 25, 2010 | 09:36 AM
Fox Fader's Avatar
Fox Fader
You need to check and see if it's fuel or fire. Try the starter fluid as instructed... Pull a plug and check for spark.
Old Nov 26, 2010 | 08:05 PM
TUFFY's Avatar
TUFFY
Had this same problem on my truck same year same engine as yours,turned out the fuel pump relay was going bad.
Old Nov 28, 2010 | 11:03 AM
01f150supecrew's Avatar
01f150supecrew
<o>></o>>
<o>></o>>
im having the exact same problem you are.
jmadsen
Jun 9, 2011 09:10 PM
FFemt5287
Jan 2, 2009 12:42 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
Animalistic
Dec 19, 2007 08:31 PM
Dominater
Apr 27, 2005 04:44 PM
