I just got a truck around a month ago and whenever i floor it and especially at low speeds it just revs up to around 4000 rpms and just sits there reved up if i let off of the gas and let the rpms go down then it will speed up a lot quicker. Is it the 35 inch tires that make this happen, it has stock gear ratios. Or is it now firing completley?? All info is greatly appreciated.
Is this automatic or stick? Sounds to me like you are slipping for sure. If it's an auto then you are looking to rebuild it. If it's a stick shift then you are looking to replace clutch assembly. Either way tranny work needs to be done.
