2bbl to log intake.
Old Nov 22, 2010 | 11:12 AM
300/6 Freak's Avatar
300/6 Freak
2bbl to log intake.
ok where do I get a log intake for a 1982 300 that will except a 2bbl carb.
Old Nov 22, 2010 | 12:00 PM
f100jim's Avatar
f100jim
The only log manifold for the 300 is the factory 1 bbl intake.
Just curious, why do you want a log manifold?
Old Nov 22, 2010 | 12:47 PM
300/6 Freak
cause I dont like the offy C but I like the 2bbl
Old Nov 22, 2010 | 02:34 PM
1986F150six's Avatar
1986F150six
Visit the Fordsix Performance forum. They have numerous threads devoted to this subject... however, the ones featured are the "small block" sixes [i.e. 170, 200, 250].
Old Nov 22, 2010 | 02:36 PM
Harte3's Avatar
Harte3
Have a machine shop mill/modify the stock intake to mount a 2v. That's what the small block 6 folks do.
Old Nov 22, 2010 | 07:30 PM
Ford_Six's Avatar
Ford_Six
I'm working on one for my van due to how tight the underhood (underdash?) area is, but I'm kinda shut down for the winter now. Basically, I'm cutting the carb mount area off a stock 1BBL intake, cutting open the outer side out to the second set of cylinders, and then welding on a new plate drilled and tapped to take a 2BBL carb with EGR. Welding rod for cast iron isn't cheap though, I spent $20 on a one pound package, plus you have to anchor it down so it doesn't warp too much, preheat and postheat to prevent cracking, and still have it milled to make it seal properly.
Old Nov 23, 2010 | 12:19 AM
300/6 Freak
well I think IF I do it. I'll just take it to a shop and say here make this bolt to this! Has anyone tried a 2:1 adapter Classic inlines sells them
Old Nov 23, 2010 | 08:32 AM
parr4's Avatar
parr4
I agree with your idea about adapting a 2bbl to the OE manifold. I too am not all the taken with the Offy intake and beside that, the price, whether new or used is high. I'm not looking to build a race truck, but would like a 2bbl for those occasions when something is needed for X-reason. Hope you can work something out. It may just be that others have similar interests.
Old Nov 23, 2010 | 09:26 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Adapters do work, just won't have as good of air flow as a direct mount due to funneling it thru the smaller hole.
Old Nov 23, 2010 | 11:14 AM
300/6 Freak
anyone got a stock intake nad exhaust manifold they want to sell
Old Nov 23, 2010 | 01:05 PM
parr4's Avatar
parr4
ebay prolly does if no one here does
Old Nov 23, 2010 | 02:27 PM
f100jim's Avatar
f100jim
They are pretty rare, but Edelbrock made a 1 bbl intake for the 300. It kept the stock YF mounting flange and even bolted up to the exhaust manifold just like stock, so the carb was in the exact same location as stock. The advantage to this was that it had six individual runners coming together at the plenum. This manifold, being aluminum, would be a lot easier to cut and weld to accept a 2 bbl, plus the individual runners would probably perform a lot better than the log intake. Unfortunately, because they are rare, they tend to be pricey. I have seen them sell for about the same as a used Offy or Clifford. I search ebay for 300 intakes pretty regularly, and I have only seen one of them for sale in more than a year.
Old Nov 23, 2010 | 02:50 PM
300/6 Freak
yeah the intakes are hard ot come by too. only one on ebaymotors
Old Nov 23, 2010 | 03:13 PM
parr4's Avatar
parr4
check your local craigslist for Ford parts trucks.
Old Nov 23, 2010 | 04:04 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Or look here:
Car-Part.com--Used Auto Parts Market
