2bbl to log intake.
Old Nov 23, 2010 | 06:44 PM
1eyedjack's Avatar
1eyedjack
Im installing a offy intake dp this sat. I will be selling my factory intake once Im sure that the offy is what i want.
Old Nov 23, 2010 | 10:04 PM
newrider3's Avatar
newrider3
Originally Posted by 300/6 Freak
anyone got a stock intake nad exhaust manifold they want to sell
I'm selling my stock intake and exh manifold (also selling the carb, egr and other parts) but I bet shipping would kill.
Old Nov 23, 2010 | 10:48 PM
300/6 Freak's Avatar
300/6 Freak
how much MONEY? stupid ten leter rule
Old Nov 24, 2010 | 12:26 PM
newrider3's Avatar
newrider3
Empty your PM box.
Old Nov 30, 2010 | 01:04 PM
CJ77F100's Avatar
CJ77F100
Do the 2 to 1 adapters work very well since they hinder air flow?
Old Dec 1, 2010 | 02:27 PM
TheWedge1's Avatar
TheWedge1
I put one of the 2 to 1 adapters on my 300 and have been very happy with it. I had to work on the mounting holes on the adapter itself (file them out) due to them being to narrow to mount to my factory intake, but other than that I feel it was money well spent. If I remember correctly the adapter wasn't but about $45-$50 shipped.
Old Dec 2, 2010 | 04:02 AM
jem44357's Avatar
jem44357
Old Dec 2, 2010 | 06:29 AM
TheWedge1's Avatar
TheWedge1
I used the adapter from trans dapt, I would question them about the measurement between the mounting holes before I ordered then measur the width between your mounting bolts to
be on the safe side. I also used a holley 350 cfm 2bbl.
Old Dec 3, 2010 | 12:59 AM
jem44357's Avatar
jem44357
I am not certain it does. I guess you would have to calculate the flow capability of the 1 barrel hole. I think if it was > or = to the need for 1 cylinder at your max rpm it would not hinder the flow. Someone with more knowledge can comfirm this, or educate us.
Jim
Old Dec 3, 2010 | 01:46 AM
300/6 Freak
well anyone want to sell their manifold?
Old Dec 3, 2010 | 03:52 AM
jem44357's Avatar
jem44357
Where are you located?
Old Dec 3, 2010 | 08:57 AM
300/6 Freak
Williston ND.
PS: i can find "NEW" exhaust manifolds but not "new" intakes anyone know where to find those?
Old Dec 3, 2010 | 09:31 AM
  #28
f100jim's Avatar
f100jim
Williston ND.
4.9 300 FORD F150 F250 NEW CAST INTAKE MANIFOLD - eBay (item 250733708946 end time Dec-27-10 11:25:46 PST)
Seller claims this new aftermarket. If it is, then there should be other sources out there.
Old Dec 3, 2010 | 09:36 AM
  #29
parr4's Avatar
parr4
check Summit racing site....I'm pret sure Dorman sells them too/Summit is a Dorman vendor
Old Dec 3, 2010 | 04:13 PM
  #30
CJ77F100's Avatar
CJ77F100
I have a 77 F100, and I don't think the adapters that jem44357 indicated above will work for my year. Between the carburetor and manifold is (for lack of a better term) a "smog spacer". I have completely removed everything attaching to the spacer. The problem is that the is an extra "hole" on the manifold that goes into this spacer (it is for the now bypassed EGR). These adapters do not look like they will fully cover this hole. This is the reason I have not removed the "smog spacer entirely and just mounted the carb on the manifold. Any ideas?
