gear ratio
Old Nov 22, 2010 | 09:22 AM
therigwelder's Avatar
therigwelder
gear ratio
I've decided I am going to change my gears.96 f450,right now I don't know what ratio I have.I do know its screaming rpms in 5th making me wish I had another gear.what is the best ratio to use?I need a hwy truck not a sherman tank
Old Nov 22, 2010 | 02:09 PM
85e150's Avatar
85e150
Not sure what tire size you have.
What RPMs are you turning at 60 mph?
Your 5 speed, is that a manual trans?
What engine?
IF you have a 33 inch tire, and a .76 5th gear, and 4.10 gears, you would be going 60 mph at 1900 rpm.
So it's hard to figure what you've got if it's screaming--shorter tires, much shorter gear...???
Old Nov 22, 2010 | 02:26 PM
therigwelder
I have a powerstroke,running7.50x16 tires,rpms 2900 at 70 mph.its a 5 speed
Old Nov 22, 2010 | 02:42 PM
85e150's Avatar
85e150
Those show as 31.5 or 32.
2900 rpm
31.5 tire
.76 high gear
4.88 axle
73 mph
Calculator here:
Novak Conversions - Gearing & Gearing Math for Jeeps
Change to 4.10s:
RPM drops to 2326 at 70.
I don't know what axle you have, so I can't search for gear sets, but you can figure that out.
Can you go to a taller tire?
33s take you down to 2643 at 70, for example.
Old Nov 23, 2010 | 08:36 PM
therigwelder
Well 7.50 is basically a 235 75 r16.I don't know how much taller tire I can get on a dually.if I put 4.10 gears I must have around a 5.13 now?
Old Nov 23, 2010 | 08:38 PM
therigwelder
And if I am not mistaken the same gearset fits in a 10.25. And a 10.50?
Old Nov 23, 2010 | 11:03 PM
85e150's Avatar
85e150
You probably have 4.88s, see post 4.
If you can't go taller tires, then the gear change is the only option unless you put an aftermarket OD in--which can be done for about $3000.
Gear Vendors under/overdrive Trucks / Towing, Chevrolet /GMC, Dodge / Dodge RAM, Ford auxiliary transmissions.
Sterling info:
Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
meborder
Mar 8, 2014 09:28 AM
southtexasidi
Aug 13, 2013 10:35 PM
91dirtydiesel
Dec 19, 2008 01:39 AM
fastestbbc
Nov 20, 2008 07:56 AM
dieseldoc
Nov 22, 2006 08:36 AM
