Replacing Shocks?
Old Nov 22, 2010 | 07:46 AM
BumpDraft2007's Avatar
BumpDraft2007
Replacing Shocks?
I was surprised to find a price of about $1400 to replace front and rear shocks. I have a 2004 Expedition w/ air suspension. I have 80,000 miles on it. I bought it used w/ 33,000 miles. The last time I was at the dealer they said they were fine - hard to believe (about 75,000 on them at the time.) Any advice/tips? What is your experience w/ how these OEM shocks last? Any aftermarket stuff that fits? I could not find any.
Old Nov 22, 2010 | 08:08 AM
alloro's Avatar
alloro
The shocks cost about $250 each to go and buy them yourself. That means they're charging you $100 per shock for installation. I suppose once you figure in taxes and shipping, you can save around $300 if you do the job yourself.
RockAuto Parts Catalog
Old Nov 22, 2010 | 09:37 AM
jokerforever's Avatar
jokerforever
Why use OEM? The aftermarket has hundreds of options for replacement shocks that don't cost $250(each!?!). Here just for a start check this out
Shocks and Struts - Suspension Components - Chassis & Suspension - EXPEDITION - FORD - 2006 - SummitRacing.com
There should be a ton of reviews on the internet to help you decide which shocks to buy. If you need help, then list all your trucks details and your intended use here and I'll help you out. I just did this job on my 01 and it only cost me $300 (for top of the line Bilsteins) and about 3 Hours.
This is a job that anybody with a basic tool kit, jack (you can use the stock one-just be careful) and apposing thumbs can do. Find yourself a manual at any parts store. Read it. Then read it again. Dedicate a Saturday and get it done. That night jump on here and tell us all about it.
Old Nov 22, 2010 | 06:49 PM
JeffHann74's Avatar
JeffHann74
****Deleted by author****
Old Nov 22, 2010 | 07:30 PM
1whoseeks's Avatar
1whoseeks
Replaced shocks on my 2002 expy with Pro Comp shocks. 100k miles.
Man what a difference. Paid 160 bucks on line from 4 wheel parts. Took about 3 hours to install. If i can do it than anyone can.
Old Nov 22, 2010 | 07:34 PM
alloro's Avatar
alloro
The ones I posted were not OEM, they were aftermarket. Remember he has the air ride suspension, not the standard one.
Old Nov 23, 2010 | 06:51 AM
2Fords1Jeep's Avatar
2Fords1Jeep
ditch the air ride!
Old Nov 24, 2010 | 03:37 AM
dbutler's Avatar
dbutler
Is there any alternative to the motorcraft shocks for these?
Old Nov 27, 2010 | 06:05 PM
BumpDraft2007
Ok - this is all very helpful - thanksto all for pointing me in the right direction. I found this:
04 2004 Ford Expedition Shock Absorber - Suspension - Bilstein, KYB, Rancho, Front, Rear - PartsGeek
They DO mention that these are for use w/ the air suspension and mention re-using the mounts and coil springs. Is that a durability or safety issue?
I have used Rancho RS5000s on three other 4WDs and liked the product.
Is there anything else you all recommend I need to know before I purchase these?
Thanks again for the advice and help.
Old Nov 27, 2010 | 08:59 PM
pdqford's Avatar
pdqford
The way I read that page it says that those front shocks on the page fit "EXCEPT Air Leveling Suspension"
IIRC, the rear shocks are the same with or without the air leveling suspension.
Old Nov 28, 2010 | 06:25 AM
BumpDraft2007
If you scroll down a ways they do have them listed for the air suspension. There is not, however, a listing for both front and rear, which seems odd to me.
Old Nov 28, 2010 | 12:38 PM
alloro's Avatar
alloro
No they don't have a listing for air ride suspensions. All of them say, "Exc. Air Leveling Suspension" except for the last two; those are QuickLIFT 9 position MANUAL adjusting ones.
Old Nov 28, 2010 | 02:13 PM
flatheadshoals's Avatar
flatheadshoals
I replaced my original shocks at 168,000 miles on a 97 Expedition. What was I waiting for? Good question, it rides beautifully now.
I was told Monroe makes the front air shocks that my local Ford Dealer sells. Don't know if that is accurate, but I was hard pressed to find another brand so I bought Monroe 40004 shocks at a local parts place @ $111 each. The rears, of course, weren't air so the choices were many, but I kept it simple with Monroe sensa-trac @ $44 each. You can get a better brand depending on your use and expectations.
polarlys
6.7L Power Stroke Diesel
23
May 3, 2017 10:54 AM
BOHAWG175
Feb 10, 2017 06:37 PM
rjfetz1
Sep 18, 2009 05:26 PM
mdwilli
Apr 21, 2009 10:25 PM
