REAL soft brake pedal after replace
Old Nov 22, 2010 | 04:17 AM
sselvia's Avatar
sselvia
I just replaced my front rotors and calipers, pads of course on my 99 expedition 4wd.
I now have a very soft pedal......like it goes way down there when it's running. ON the first pump when it's not running the pedal will go to the floor, but pump up after several pumps but not all the way to the top. I have bled and re-bled the system(all four wheels). Does not appear to be any air......but sure feels like a lot of it by the pedal. Ideas please!!
PS....what kind of idiot design those stupid torx head bolts for the calipers anyway?!!!
Old Nov 22, 2010 | 07:29 AM
alloro's Avatar
alloro
I'm sure there's still air in the new calipers. Bleed them once again, but this time rap on the calipers while you're doing it. The vibration will cause the air bubbles that are clinging to the insides of the caliper to break loose and rise up to the bleed screw.
Old Nov 22, 2010 | 09:54 AM
sselvia's Avatar
sselvia
Thanks, will do. I can't see anything else that could be wrong really!
I've done lots of brakes in my 52 years!
And as a matter of fact the new caliper I put on has the bleed screw at the bottom instead of the top??? Don't get that one??
Old Nov 22, 2010 | 07:06 PM
alloro's Avatar
alloro
That's odd! Do you have the calipers installed on the wrong sides of the vehicle?
Old Nov 22, 2010 | 08:29 PM
sselvia's Avatar
sselvia
Well I only replaced the left side. I guess I boils have been the wrong one now that u mention it I didn't get the box asvghey kept it to put the core in. I think o will check with them tomorrow. Should still bleed out no??
Old Nov 22, 2010 | 08:47 PM
alloro's Avatar
alloro
Should still bleed?
I wouldn't waste the time or the brake fluid until you can confirm the correct caliper is in there. With the bleed screw on the bottom, there has to be an air pocket in the caliper that will never come out.
Old Nov 22, 2010 | 08:53 PM
sselvia's Avatar
sselvia
So I will take it off and exchange tomorrow. I'll report after that. I guess it does make sense that air will stay in the top. And instead of the fluid on top moving the piston there is an air cushion at all times. That very strange but likely what happening I guess.
Old Nov 23, 2010 | 05:56 AM
sselvia's Avatar
sselvia
Please see this post for more details.
https://www.ford-trucks.com/forums/1...difficult.html
Old Nov 23, 2010 | 04:15 PM
thecardoc's Avatar
thecardoc
My guess would be that the parts store either sold you the wrong side caliper or it was boxed wrong. Whatever the case the bleeder screw MUST be on the top.
Old Nov 24, 2010 | 10:14 AM
sselvia's Avatar
sselvia
Yep.....I think your right. I'll get to the bottom of it over the long weekend. I'll report how it went FYI.
Thanks for the help so far, yo guys have a great Thanksgiving!
dwstenersen
16
Apr 11, 2017 08:11 AM
danlee
13
Apr 3, 2017 08:54 PM
79fordf100styleside
Jan 30, 2017 10:06 PM
bigcrushjake
May 13, 2016 10:55 AM
fordex007
Oct 23, 2015 11:49 PM
