rear end gears
Old Feb 28, 2003 | 01:53 PM
custom_truker's Avatar
custom_truker
rear end gears
what would you guys say is the best rear gears for a 78 f100 with I6 and 3 speed on the tree without sacrificing highway speed too much?
Old Feb 28, 2003 | 02:28 PM
whittey's Avatar
whittey
rear end gears
What size tires? Are you planning on much towing?
-=Whittey=-
Old Feb 28, 2003 | 03:45 PM
fordtruckin's Avatar
fordtruckin
rear end gears
3.55's are great on my truck!
Old Feb 28, 2003 | 06:03 PM
steve83's Avatar
steve83
rear end gears
I'm going back to 3.08 as soon as I can.
Old Feb 28, 2003 | 07:06 PM
tetraruby's Avatar
tetraruby
rear end gears
Steve what are you switching from? With what size tire? Why? Just curious. - mileage?
Old Mar 1, 2003 | 06:40 AM
custom_truker
rear end gears
whatever the stock tire size is. I am not sure exactly. It needs to be able and haul a load in the bed, but probably not much towing. At least not very often.
Old Mar 1, 2003 | 07:52 AM
StrangeRanger's Avatar
StrangeRanger
rear end gears
With a 3 speed, you don't have a lot of options. Your 3rd gear is 1:1 os for decent highway RPMs you want a 3.08 which give you about 2400 RPM @ 65 or even a 2.73 which drop it to about 2150.
Since your 1st gear isn't very deep, neither of these gears have any acceleration, performance or hauling capability. A set of 3.55s or 3.73s would be much better for a working truck but you'd end up pulling 2750-3000 RPM @ 65 depending on tires.
If you go with something in the middle like 3.27s or 3.31s you'll still be turning about 2550 @ 65
Old Mar 1, 2003 | 07:50 PM
steve83's Avatar
steve83
rear end gears
tetraruby
You can see my truck specs in my profile, and more in my sig link. I'm going back to 3.08s because I do have a granny gear AND a transfer case with low range (so I don't have a torque problem), but I don't have OD, so the 3.55s I'm running temporarily just won't get me up to the speed I like. I can't even peg the speedometer any more.
Old Mar 1, 2003 | 10:43 PM
custom_truker
rear end gears
thanks for the advice. I will probably just keep things the way they are and keep the work load down on it. It will mostly be used just for commuting anyway, and I could use the lower rpms for better fuel mileage with the way gas prices are going up where I live. I have put some decent loads on it and it has done alright, not the greatest, but it has gotten the job done and that is all I need for right now.
Ianrhall
1947 and Older Ford Trucks
Dec 14, 2014 09:12 PM
Tim66250
Nov 20, 2014 05:47 PM
eminencefront
Sep 28, 2014 11:34 AM
hulaman
Oct 8, 2012 09:49 PM
Brandan78
1978 - 1996 Big Bronco
Mar 1, 2007 02:07 AM
