1978 - 1996 Big Bronco
Rear Ends and Ratios
Old Feb 27, 2007 | 04:00 AM
Brandan78's Avatar
Brandan78
What rear end and gear ratios were common in the 87 302 4 speed and 90 302 5 speed broncos?
Old Feb 27, 2007 | 08:33 AM
Kemicalburns's Avatar
Kemicalburns
3.55 was the most common. 4.10 was an option and so was 3.08.
Old Feb 27, 2007 | 11:07 AM
Brandan78's Avatar
Brandan78
were they matched up in any particular way to the transmission? also is the axle tag the same format as my ranger's?
Old Feb 27, 2007 | 11:59 AM
Kemicalburns
I dont know if they are matched to the tranny. the axle tag should be simlar. do a search with what yours says. should come up with something like 3l55 type thing
Old Feb 27, 2007 | 01:29 PM
MBBFord's Avatar
MBBFord
I had never seen 3.08s in a Bronco until I saw my buddy's 89.
I've heard of it once, but wasn't sure if it was true. I have never seen a stock bronco with 4.10s, but have heard of people with them every now and then.
Like kemicalburns said, the axle tag on the rear bolt cover should read 3l55 for a 3.55 gear ration w/ limited slip or 3.08 for 3.08 gears w/ open diff.
Both will have a 8.8 rear end.
Old Feb 27, 2007 | 04:40 PM
Brandan78's Avatar
Brandan78
ok thanks. were just trying to decide if we should pair up the axle from the 4-speed with the 5-speed tranny or vise-versa.
Old Feb 28, 2007 | 09:00 AM
Kemicalburns
the tranny wont make a difference. you must make sure the gear ratios match front/back otherwise you will have major carnage
Old Mar 1, 2007 | 02:07 AM
Brandan78's Avatar
Brandan78
yea i should have said axles. since the axles from the 4-speed have less mileage
civicmindeddogooder
29
Jan 16, 2013 09:41 PM
dnachristen
Bronco II
Jan 6, 2006 04:04 PM
alwaysmessedup
May 21, 2003 01:55 PM
smile5484
Nov 7, 2002 05:18 AM
Ford78_302
Apr 10, 2000 10:58 PM
