locate fuel pressure regulator
Old Nov 21, 2010 | 12:29 PM
jgaspard's Avatar
jgaspard
i just bought a 2003 F250 Super duty with a 6.0 and i need to locate the fuel pressure regulator as soon as possible can someone please help
Old Nov 21, 2010 | 03:28 PM
LxMan1's Avatar
LxMan1
moved to correct forum
Old Nov 21, 2010 | 03:50 PM
npccpartsman's Avatar
npccpartsman
The fuel pressure regulator is under the cover pictured here: Page 30: Fuel Supply System
Old Nov 21, 2010 | 03:58 PM
jgaspard's Avatar
jgaspard
Fuel pressure regulator
The pressure regulator that i got from the ford dealer has a plug on it and i don't see any wires in the photo where do i plug it in
Old Nov 21, 2010 | 04:39 PM
JLarsson's Avatar
JLarsson
Ford 6.0L Diesel - No wires involved in the fuel pressure regulator. Could you possibly be referring to the fuel pump? It's located on the inside of the frame rail under the driver's seat.
Old Nov 21, 2010 | 04:47 PM
dchamberlain's Avatar
dchamberlain
He's probably referring to the Injector Control Pressure Regulator (IPR). Apparently the Ford parts manual calls this the fuel pressure regulator.
Old Nov 21, 2010 | 05:04 PM
JLarsson's Avatar
JLarsson
That makes sense, for sure.
Old Nov 21, 2010 | 05:08 PM
npccpartsman
IPR valve on an 03 is on the top back of the motor UNDER the turbo along with the ICP sensor. Page 11: Component Locations
Not really a good picture but that's where it is. Does it look like the gold one in this picture: Page 64: Electrical Components ?
Old Nov 21, 2010 | 05:18 PM
jgaspard's Avatar
jgaspard
that's the one, so it does go under the turbo can you tell me about how long it takes to change and if i need any special tools
Old Nov 21, 2010 | 05:39 PM
npccpartsman
There is a great writeup here: https://www.ford-trucks.com/forums/8...ml#post7693493
Check out the tech folder at the beginning of the 6.0 forum for answers to virtually ALL your 6.0 questions. Great info there.
Old Nov 21, 2010 | 05:44 PM
jgaspard's Avatar
jgaspard
Thank you so much it is a big help
Old Nov 21, 2010 | 05:46 PM
npccpartsman
You're very welcome
CapitanRon
20
Jan 14, 2015 04:20 PM
jsavin
Feb 26, 2013 08:26 PM
Camp250
Apr 3, 2012 09:10 AM
slbuckl
Escape & Escape Hybrid
Jul 16, 2011 07:49 AM
95TBird
Aerostar
Jul 19, 2010 01:23 PM
