Radiator problems?
Old Nov 19, 2010 | 03:01 PM
Scratcher's Avatar
Scratcher
Radiator problems?
I just changed my water pump, thermostat, and bottom and top hose. My heaters work perfectly but when I feel the bottom hose after a good run its still cold even though the top hose is hot. The bottom of the radiator is cold too while the top is hot. What gives
Old Nov 19, 2010 | 03:18 PM
tecgod13's Avatar
tecgod13
Not that the factory gauges are that accurate, but what temp are you running at?
The factory radiator is big on these, and unless you're really pushing it, they tend to be overkill. As long as your temps are good and its not overheating, don't worry about it.
Old Nov 19, 2010 | 03:20 PM
Scratcher's Avatar
Scratcher
The temp gauge is sitting where it always does. No overheating........Weird!
Old Nov 19, 2010 | 07:10 PM
axe_handle's Avatar
axe_handle
Given the size of the radiator, I'm not surprised that the lower hose is cold. I've never actually checked mine though.
Old Nov 19, 2010 | 07:13 PM
ford390gashog's Avatar
ford390gashog
Thats the point of a heat exchanger Yours is working hot fluid comes in the top and after the heat is removed cooler fluid exits from the bottom hose. Sounds like its working fine to me.
Old Nov 19, 2010 | 07:26 PM
rodneywar's Avatar
rodneywar
yea man its normal dont worry about it mine does the same thing
Old Nov 19, 2010 | 10:09 PM
wreckinball's Avatar
wreckinball
2nd or 3rd or whatever, its working normal! Do you have a mechanical gauge?
Old Nov 20, 2010 | 05:10 AM
Scratcher's Avatar
Scratcher
Stock gauge
97vanswap
May 12, 2015 01:07 AM
catzr440
May 5, 2015 08:43 AM
saauvenshine
1947 and Older Ford Trucks
Mar 9, 2015 08:43 PM
GKTECC
Jan 31, 2015 12:15 PM
ERF
Jan 7, 2015 08:43 PM
