Convert to Delay Wipers?
Old Nov 19, 2010 | 07:19 PM
jim collins's Avatar
jim collins
I just bought three off of ebay, take your time and get a good buy. The best one was only $13.00 ,had all the wires for the washer. Two of them were for 80s ,i used one in my 64 falcon as it has no washer. Yes they will fit the falcon if you use the 79 wiper motor. The ones for 80s have one wire missing, I never new that when i bought the first two. So , just because they say its for 79 and older,if you need the washer ask them if all the wires are in it. They are plug and play , just need to hook up the ground wire that is attached.
Old Nov 19, 2010 | 10:06 PM
wasa 1500's Avatar
wasa 1500
I just did my dent, pull a part 80's pick pu, un plugged my switch ( 2 pin and the other one) it pluged in to the one going to the box and it is connected to the new switch. Ground the switch and it works great.
Old Nov 19, 2010 | 11:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I used an 80s unit as well. Works like a charm.
Josh
Old Nov 20, 2010 | 06:58 AM
Supercab's Avatar
Supercab
Guys, These units can also be had from mid-late 70s TBirds and Cougars-same unit!
Old Nov 20, 2010 | 09:48 AM
Justin's Green Truck's Avatar
I bought one of these from ebay a while back and installed it on my 77. You'll love it. So much more handy.
NOTE: If when you hook it up, your washers dont work, unplug the electrical connector, turn it around the other way, and reconnect it. This happened to me and I had to do a search on here and that's what it was. Apparently the connector will go either way and all you have to do is turn the connector over and plug it back in to get the washers going. Some things really are that simple I guess.
Old Nov 20, 2010 | 12:01 PM
steponit's Avatar
steponit
It is much easier to just get the proper year governor
The older T-Birds/Mercury's had a different switch and governor and will not work in a truck.
Old Nov 20, 2010 | 12:57 PM
1977f250's Avatar
1977f250
Get one from a mid 80s truck. Most have them and you can get them on the cheep from the junkyards. If you can change the switch you can do this. I have done 3 trucks this way and it is that easy. Read up and search for intermittent wipers ( wiper delay dont bring up much) look here https://www.ford-trucks.com/forums/9...nt-wipers.html
Old Feb 6, 2011 | 09:34 PM
Robertcoupe's Avatar
Robertcoupe
A+ thread,
its nice to find a solid answer for a problem
MrBlue54
Jan 22, 2016 02:16 PM
rangernut09011980
Sep 20, 2015 10:12 PM
1978f-250
Apr 5, 2014 09:53 AM
turnkyle
Dec 31, 2011 11:53 AM
Boss F150
Jan 10, 2010 07:08 AM
