That would be awesome because the switch is fairly cheap all things considered.
I think there is an attached box which is the timer ?? but I think it was wired directly to the replacement switch, but it been awhile since I added that setup to a truck as I have a friend that brings me all his 73-79 trucks for work but like I said its been a few years and I have worked on hundreds of other cars/trucks since..
Well LMC sells the standard switch for $14.99 and the switch for delay wipers at $44.99. Seems like the cost difference might include the regulator box. They don't mention it separately anywhere that I see.
just make sure you double check on that one as now that I think about it I think I remember there that seperate short harness with a plug attaching the 2 as "White 97xlt stated , but my friend always brought that conversion to me as a unit.. this is an easy job and shouldnt take you more that 20mins to do as long as the control box is included with the switch..
hmm... hate to buy the switch and it NOT come with the box. Sounds like a question for Numberdummy....
I just ran down to the shop and checked as I forgot I actually have one of his trucks here, but go figure this is the only truck he has that doesnt have delay wipers!! LOL
I've read some people just grab the switch and delay box from the 1980-1991 trucks. Supposedly it works but you have to plug your washer pump connector in upside down after the swap. ? I actually bought 2 set ups from late 80s truck but have not had the time to try them out yet on my 1976 and 1977 so I can't verify this works but the connector is the same. Try a search and you'll find several threads stating this.
