Instrument cluster swap help...
Old Nov 21, 2010 | 03:35 PM
  #31
Anafiel's Avatar
Anafiel
Two screws on the speedo, lens swaps right over. No problems. All I have to do now is hit the hardware store in the morning for connectors, and I'm good to go.
Old Nov 21, 2010 | 10:06 PM
  #32
TheKirbyMan's Avatar
TheKirbyMan
Not to sound critical, but why didn't you just swap over the circuit film? So long as both are for the full gauge cluster and not idiot lights, it would be a direct swap, and you'd only need to wire up the tach. Just curious.
Old Nov 21, 2010 | 11:27 PM
  #33
Anafiel's Avatar
Anafiel
I thought about that, but I decided to take the opportunity to completely clean the whole assembly during the swap-over, but most importantly I didn't want to take the chance of damaging the film by moving it.
Really, I just wanted to leave it where it was, and move the gauges I need instead. I was informed in another thread, and I quote "YOUR SPRINGS ARE SHOT", so I would rather spend my money there, than spending a hundred on something that works now...as long as I don't go screwing it up.
My wife hates paying for my screw-ups.
Old Nov 22, 2010 | 11:16 AM
  #34
Anafiel's Avatar
Anafiel
Mission accomplished. Everything works, all connections done "right". No questionable rigging. I may even wind up with my shift indicator working...
You know, I just want to take a moment to thank all of you that offered suggestions in this rather long thread. Really...thanks.
So, was this little project an easy "in and out"? Nope. Was it worth it? YOU BET!
Old Nov 22, 2010 | 12:37 PM
  #35
81-F-150-Explorer's Avatar
81-F-150-Explorer
Most of these swaps are a lot easier than yours turned out to be. It looks good in there to have full gauges than a blank in the middle doesn't it?
Does the ammeter gauge work though? It looks a little off from the picture.
Old Nov 22, 2010 | 01:53 PM
  #36
Anafiel's Avatar
Anafiel
Yea, the dash looks "complete" now.
The ammeter works, but the needle is just off of "0". The ammeter on the other cluster was just as far off, but in the discharge direction. I assume there is a zeroing screw on the backside of the gauge, but those needles are SOOO fragile, I didn't want to take the chance of bending it by trying to take the gauge out to adjust it.
Old Nov 22, 2010 | 09:14 PM
  #37
ctubutis's Avatar
ctubutis
As I seem to recall, during normal operation when everything is working correctly, they are
pretty much always just to the right of the center tick mark, even with the ignition shut off.
The only time it'll hang to the left is when the charging system isn't doing its job.
My ammeter seems to work pretty well, I've seen it deflect around one half of the way to
the right after starting it up with a somewhat-discharged battery.
Old Nov 23, 2010 | 01:15 PM
  #38
81-F-150-Explorer
With the engine off, it should be straight up and down, or to the left toward discharge. It should not read charge with the engine not running.
With the engine running, fully charged battery, it should be just to the right of the center mark.
To recenter the gauge, you will have to bend the needle. Being very carefull this can be done with needle nose pliers, or tweezers.
While I was in there I would repaint the needles with flourecent orange, or flourecent red paint as well.
But these are only suggestions....
Old Nov 23, 2010 | 04:07 PM
  #39
Anafiel's Avatar
Anafiel
Good idea, repainting the needles. I'll have to take the time soon to go back in and do those little tweaks.
Thanks!
Old Nov 24, 2010 | 07:44 AM
  #40
00Boss's Avatar
00Boss
Howd you pull your headlight and wiper ***** Im just about to start the same project
Old Nov 24, 2010 | 08:19 AM
  #41
Anafiel's Avatar
Anafiel
Wish I could help you there, but my truck came with no *****. I got replacement ***** at the auto parts place, and they just push on and off. Donor truck also had aftermarket *****.
I understand the factory ***** are a BEAR to remove. Maybe someone else watching this thread can help you with that??
Good luck with your project. I hope something here has helped you with it.
Old Nov 24, 2010 | 11:30 AM
  #42
JimsRebel's Avatar
JimsRebel
Here is a thread with good info and some pictures
https://www.ford-trucks.com/forums/9...b-removal.html
Old Nov 24, 2010 | 12:35 PM
  #43
00Boss's Avatar
00Boss
Iv fallowed a few threads on this project and everyone of them has had some different info. thank you
Old Nov 24, 2010 | 01:21 PM
  #44
TheKirbyMan
You can get an angled pick tool (looks like a dentist's pick), stick the pointed end into the back of each **** and move the spring-metal retainer clip til the wiper **** comes off. You'll be working blind so be patient.
To remove the headlight switch ****, you can reach up under the dash and feel around for the headlight switch. On the bottom there should be a plastic or metal button; press that while pulling on the headlight switch **** and the **** and shaft should come out as an assembly.
Old Nov 24, 2010 | 05:49 PM
  #45
00Boss's Avatar
00Boss
I think the wiper **** was superglued on. I need to disconnect the speedometer but cant seem to figure it out.
