C4 Issues
1. The transmission would not upshift from 1st to 2nd. It would though shift down from 2nd to 1st. I hate to say this but this may have been caused by negligence. I had had the truck for about three days and had to take it to a mechanic. The dashboard display indicating which drive it's in doesn't work so I was going by feel. In any case I think the transmission may have been in drive when it was towed. After this point is when the 1st to 2nd gear stopped working. My question is can these two events be related and if so what should I look for while overhauling.
2. I drove the truck for a few years like that (would start from a stop in drive 2) but eventually the reverse went out. I have to admit it happened after an incident where I was making a 3 point turn on a slight hill. Rather than wait for the truck to fully stop I did the ole engage reverse a bit early (learned my lesson). After this I made the decision to overhaul the transmission. While removing the extension housing I found half a snap ring laying in the housing. I've come to realize this is the snap ring that holds the governor distributor body (and i.e. the governor) in place. With this snap ring gone the distributor body slides back and forth about an inch or more. Could this broken snap ring be the cause for the lack of reverse? If not what else could be causes for such a sudden stopping of the reverse function.
Thanks again for any assistance.
