C4 Issues
Old Nov 18, 2010 | 05:32 PM
shark13's Avatar
shark13
C4 Issues
Hello everyone, I've got some issues with my transmission. Any help would be greatly appreciated. There were two things that were not working on my C4 transmission (from 81 F100) that caused me to take it down and begin an overhaul. I wanted to ask whether anyone might have any ideas as to what to look for during this process to help identify the causes. Below are the issues.
1. The transmission would not upshift from 1st to 2nd. It would though shift down from 2nd to 1st. I hate to say this but this may have been caused by negligence. I had had the truck for about three days and had to take it to a mechanic. The dashboard display indicating which drive it's in doesn't work so I was going by feel. In any case I think the transmission may have been in drive when it was towed. After this point is when the 1st to 2nd gear stopped working. My question is can these two events be related and if so what should I look for while overhauling.
2. I drove the truck for a few years like that (would start from a stop in drive 2) but eventually the reverse went out. I have to admit it happened after an incident where I was making a 3 point turn on a slight hill. Rather than wait for the truck to fully stop I did the ole engage reverse a bit early (learned my lesson). After this I made the decision to overhaul the transmission. While removing the extension housing I found half a snap ring laying in the housing. I've come to realize this is the snap ring that holds the governor distributor body (and i.e. the governor) in place. With this snap ring gone the distributor body slides back and forth about an inch or more. Could this broken snap ring be the cause for the lack of reverse? If not what else could be causes for such a sudden stopping of the reverse function.
Thanks again for any assistance.
Old Nov 19, 2010 | 08:16 AM
Lazy K's Avatar
Lazy K
Not an expert but my guesses would be that the governor issue was the cause of it starting out in second and that you have a broken low/reverse band causing no reverse.
sea2seajt
2004 - 2008 F150
Oct 8, 2014 01:32 PM
goodtyms1432
Jul 1, 2013 06:21 PM
keiser
May 23, 2013 03:03 PM
dmal
Feb 10, 2013 02:58 PM
shark13
Dec 14, 2010 03:15 AM
