Speedometer bouncing
Old Nov 18, 2010 | 12:50 AM
3cornersranch's Avatar
3cornersranch
The speedometer on my girls 79 F150 bounces around after about 65 mph making it hard to tell fast she going or what the cruise will be set at. Any ideas? It a 79 supercab with 400/C6 2wd ranger xlt
Old Nov 18, 2010 | 01:14 AM
bmuhlbach's Avatar
bmuhlbach
probably the speedometer cable is bad.That is what they do or they just quit working
Old Nov 18, 2010 | 04:24 AM
seventysevenF150's Avatar
seventysevenF150
I've had the same problem. maybe not the same fix though. I took the instrument cluster out of the truck, spray penetrating fluid (WD-40, Liquid Wrench) down the speedo cable and drive for a bit. This fixed mine. Try it a couple times and if it doesn't help then the cable might be stretched or something, requiring a new one. Hopefully this helps
Old Nov 18, 2010 | 07:47 AM
raytasch's Avatar
raytasch
Believe Nothing
As suggested above, try lubricating the speedometer cable. You might save it. You probably notice the unwanted "bouncing" when the weather is cold. It was common years ago to purchase special lub in a small tube.
Old Nov 18, 2010 | 09:15 AM
3cornersranch
Thanks
I'll try lube and if that don't work I try a new one.
Old Nov 18, 2010 | 09:17 AM
Nathan Plemons's Avatar
Nathan Plemons
I took my cluster out once to replace some bulbs and clean it up a little. When I put it back the speedo didn't quite work right. It would go up and fall, up and fall. I apparently didn't have the cable seated right.
Old Nov 18, 2010 | 09:26 AM
704 dentside man's Avatar
704 dentside man
I'd suspect the cable needs greasing as well. Beyond that, the cable could be damaged, or the drive or driven speedo gear could be on its way out.
Old Nov 18, 2010 | 11:49 AM
teflon_jones's Avatar
teflon_jones
Mine does that intermittently. It'll go away for no apparent reason and then come back again. I just look at where the middle of the "bounce" is and figure that's my speed.
Old Nov 18, 2010 | 03:03 PM
trap4x4's Avatar
trap4x4
With the cruise option, there are two seperate cables tied together at the speed sensor on or by the drivers inner fender. You can access both from there and use lithium grease to shoot down inside the cable... saves taking the dash apart or pulling the driven gear off the tranny. You may end up having to replace, but may work.... Not sure were you live, but the cable will give a lot better if you're in warmer climate...
Old Nov 18, 2010 | 03:21 PM
3cornersranch
I wondered about that. I had noticed the speed control sensor and that it was 2 piece cable, but the auto parts websites are ony showing one length for her truck. Now I just need a chance to check it out, a high school girl in love with her old Ford are hard to seperate.
Old Nov 18, 2010 | 03:29 PM
ford390gashog's Avatar
ford390gashog
Take the cable apart and clean and grease it thats what i do. The connector towards the speedometer pulls right off and the cable comes out clean the tube with brake clean and use a Ford approved moly fortified grease.
88_F0RD
15
Dec 4, 2016 12:45 PM
smokeywagon
Sep 4, 2014 09:20 PM
Hughesjr84
Feb 7, 2014 08:13 PM
cowboyty
Aug 30, 2006 03:46 PM
Natron
Aug 10, 2005 05:43 PM
