87 B II oil leak around oil filter.
11-17-2010, 03:01 PM
on
So my brother has a 87 B II around the oil filter. It leaks on one side of the filter. He change the filter and same thing. Any ideas? Thanks
11-17-2010, 03:17 PM
The usual cause for a filter leaking is double gaskets. Make sure the old one comes off when replacing.
11-18-2010, 05:40 PM
on
I hope to remove the second oil filter that my older brother removed soon to confirm this. Is there an O ring in the 90 degree adapter? Thanks
11-18-2010, 06:08 PM
on
A picture
Thanks
11-18-2010, 06:11 PM
Leak looks like it coming from higher up than the filter, thats just where its running down to.
Think valve cover gaskets.
11-19-2010, 08:55 PM
on
YES there is a O ring in that adapter! I remember replacing mine a few years back..UGH!!!
11-20-2010, 10:19 AM
on
I will pass this on to him. Thanks
Quote:
Originally Posted by
Old93junk
11-20-2010, 05:05 PM
on
if its your valve cover leaking, clean the inside of the motor out. theres a good chance that the oil isnt draining back down to the pan fast enough causing the valve cover gasket to leak. And trash that fram filter. use motorcraft. i have had a few mechanics tell me that they cause problems and i had a 15 psi increase in oil pressure when i stopped using them when i had my ranger.
11-24-2010, 09:34 AM
Oh no, it's a Fram!
Ever cut one of those open?
11-26-2010, 07:55 PM
on
11-26-2010, 09:11 PM
12-01-2010, 12:48 PM
on
I helped my bother last night and I tighed both the valve and oil pan bolts.
I only turned them 1/8 to 1/4 a turn to snug them up. Most if not all needed snuging.
Keep ya posted.
12-17-2010, 12:28 PM
on
My brother says he does not see any leaks BUT he does not drive much, under 5K a year, so he has not gone on a "trip" over 5 miles yet.
Thanks and keep ya posted.
02-18-2011, 03:06 PM
on
02-19-2011, 04:22 PM
on
Agree. The leak at the filter is gone but it still smells after it warms up.
