Shutter starting heavy load.
Old Mar 25, 2011 | 03:01 PM
  #31
jaybread's Avatar
jaybread
It is a driveline angle issue, there is a TSB from a few years ago on this.
My 08 F250, 08 F350 DRW and now my 11 F450 all exhibit shudder when loaded and taking off from a stop using more than 50% throttle.
My F250 was the worst, but it sagged the most under the load of my 5th wheel.
Go to the TSB section on the forum you will find it. It isn't the differential, as you discovered.
Old Mar 25, 2011 | 04:32 PM
  #32
marchare011's Avatar
marchare011
Thanks jaybread,
I will look that up. Did you have yours fixed?
Old Mar 25, 2011 | 04:57 PM
  #33
EpicCowlick's Avatar
EpicCowlick
Just a thought, if rear end sagging is causing drive line alignment issues, maybe airbags would help? You can very easily correct the rear sag two inches that way.
Old Mar 25, 2011 | 05:23 PM
  #34
jaybread's Avatar
jaybread
I never did the fix because the TSB says that you may cause a shudder when driving unloaded if you fix the loaded condition. I mostly drive unloaded and didn't want to tempt fate.
The shudder is only slightly annoying, so it wasn't worth effort to me.
If I were always loaded, I would do it.
Air bags would help because the issue is related to drive line angle when loaded.
My F450 has very little of the issue I am guessing because it sags less when my 5th wheel is on it.
I have had the same 5th wheel with all 3 trucks, so that is a constant.
Old Mar 25, 2011 | 05:27 PM
  #35
jaybread's Avatar
jaybread
Here is TSB:
09-20-5*** SHUDDER OR VIBRATION ON ACCELERATION - ESPECIALLY WHEN LOADED
Old Mar 25, 2011 | 06:38 PM
  #36
marchare011
Cool. Thanx guys for the info. Helps with the nerves a little bit. So, what kind of damage am I doing, if any? I only the tow the 5er 5-8 times a year. 18k toyhauler. Usually one extended length trip. This year, CO, UT, MN. Several 150-250 mile jaunts.
Old Mar 31, 2011 | 12:56 AM
  #37
jaybread's Avatar
jaybread
I am doubtful any damage is occurring, but using less power when taking off from stop will reduce shudder.
It is high torque required to get vehicle in motion from a stop that combines with drive line angle to create slipping/binding feeling of shudder. The drive line at that angle stores and releases tension causing the effect under that loading.
It is really a driveabiltiy issue related to customer comfort and not a risk to drive line.
kevmiester
Apr 15, 2017 12:54 PM
PeteNel
Jan 4, 2017 10:32 AM
motorhead5673
1997 - 2003 F150
Dec 12, 2009 08:54 PM
coldfront
2009 - 2014 F150
26
Sep 25, 2009 08:38 PM
fisherj
Oct 2, 2007 05:09 PM
