injectors leaking
Old Nov 17, 2010 | 09:47 PM
  #31
wreckinball's Avatar
wreckinball
yeah thats all i meant in the post about the washers, just double check to eliminate possibilities.
Old Nov 18, 2010 | 08:58 AM
  #32
andrew1's Avatar
andrew1
Ok just checked the filter and it's not full. So I guess the injectors are out or are they I have air somewhere . Where do I begin??????
Old Nov 18, 2010 | 02:45 PM
  #33
tecgod13's Avatar
tecgod13
Begin with re-reading the replies in this thread!!!
To summarize some of the responses, I would take out the injectors and clean out the bores. Check on the copper washers, should be one at the bottom of each injector hole. If you didn't remove the old ones, do that now.
Then, install the injectors, torque them properly and replace the injector return lines. Follow the directions in the following thread, and MAKE SURE TO USE NEW O-RINGS. If you want to be cheap, reuse the existing plastic caps but use new o-rings and hose.
https://www.ford-trucks.com/forums/8...ml#post7390771
If the filter isn't full, air is leaking into the return lines and the fuel drains back to the tank.
To get the o-rings cheaply, use McMaster-Carr, they are #111, see link below.
McMaster-Carr viton o-rings #111
Old Nov 18, 2010 | 06:16 PM
  #34
andrew1's Avatar
andrew1
just checked everything copper washers looked ok. but i notice 2 injectors had plenty of diesel on the tip and the rest was clean, dont know if this means anything. O-ring kit wont be in until tomorrow so i'm basically stuck til then.
Old Nov 18, 2010 | 07:00 PM
  #35
johnboggs21's Avatar
johnboggs21
sounds like you might have 2 leaky injectors
Old Nov 18, 2010 | 07:06 PM
  #36
andrew1's Avatar
andrew1
okay I'll called the diesel shop tomorrow, if i had the time i would do ebay. Much much cheaper
Searcysautos
18
Feb 21, 2016 06:27 AM
Cory West
1997 - 2003 F150
Sep 29, 2015 03:52 PM
Dutter 2
61
Aug 26, 2015 12:04 AM
86-IDI
Oct 20, 2014 02:45 PM
MauleOne
Sep 13, 2014 12:03 PM
