Hey guys, I'm trying to get a boost gauge to work and it does but the line from a tapped elbow is drawing a vacuum instead of pushing boost. Whats going on?
if you put a gauge connection on the inlet side of the turbo (between air cleaner and turbo) you will not be showing "boost". In order to see boost, you have to be after the pressurized side of the turbo someplace.
You won't see any boost to speak of until you put the motor under a load.
I just took it for a drive and did the VGT relearn and the most I would see was 3-4 and that was going up a hill, it's ******* compared to how it was. Aside from the CAC silicon coupler things what else could cause this? I still hear the turbo whine but just not getting any boost. Is there a smoke test to find leaks?
