PHP chip problem??
Old Nov 16, 2010 | 11:02 AM
Brown Falcon's Avatar
Brown Falcon
PHP chip problem??
When I am in my two hottest tunes accelerating hard it feels like my truck just stops pulling hard once it gets up to about 65mph or so.
Doing the same thing with my manul TC lock switch on it pulls hard as long as I have my foot in it.
Is there something wrong with my chip programming for the transmission? The TC seems to be slipping when I let the tranny do it's own thing with the chip...
Old Nov 16, 2010 | 11:44 AM
Talyn's Avatar
Talyn
I have it happen on occasions, but usually its due to lack of oil pressure in the heads, the 15's just can't keep up with a long acceleration and stage 1's.
Old Nov 16, 2010 | 12:06 PM
JamesHajek's Avatar
JamesHajek
yep, i'm going to say its probly running low on oil. But might be a good question to call PHP with...
Old Nov 16, 2010 | 01:08 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Do the RPMs increase while the truck stays at the same speed?
If not, it's not a transmission concern.
Old Nov 16, 2010 | 02:01 PM
Brown Falcon
It seems like the RPM's do keep increasing but the speed doesn't once it hits a certain point.
But when I manually lock the TC it will work fine.
Old Nov 16, 2010 | 02:35 PM
rideracelivemx7's Avatar
rideracelivemx7
how does boost look with out the lock up switch and after
Old Nov 16, 2010 | 02:50 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
My next suggestion is to run it up with your torque converter apply switch off, let it do it's "topping out" thing and then while still under load, flip the switch on and let us know what the RPM does.
Old Nov 16, 2010 | 04:01 PM
bad12jr's Avatar
bad12jr
Mine has that feeling on stock sticks espescially on the 140hp tune. My pump levels at 2000 psi though. After a certain point it just feels like it quits pulling. But I have a 5 spd so...
Old Nov 16, 2010 | 04:54 PM
427 fordman's Avatar
427 fordman
If your rpms are going up and not increasing speed you got problems. Sounds like tranny slipping to me. Hope that's not the issue.
Old Nov 16, 2010 | 08:15 PM
Brown Falcon
Havn't gotten a chance to try it again. I'll check the boost next time and try switching the TC on part way through.
I really hope it isn't the trans slipping. It only has 20k on it, factory reman. Another reason why I can't wait to put the ZF5 in it.
fordguy390
Aug 10, 2016 08:37 PM
Jaime74656
Jan 27, 2016 09:54 PM
Robbgt
52
Mar 25, 2008 03:44 PM
ernesteugene
22
Mar 13, 2007 02:48 AM
fred m lewis
Computer Chips & Tuners
Dec 27, 2001 09:54 AM
