jolt while driving
Old Feb 27, 2003 | 06:44 PM
dbarracuda's Avatar
dbarracuda
Question jolt while driving
Hey guys
I just got my tanny rebuilt but I have this problem. It was there befor the rebuild so I doubt its the tranny. When driving if you let off the gas pedal quickly it wil jolt. This also happens if your foot is not on the pedal and you give it gas quickly. Any ideas?
Thanks
David
I forgot to say that it is a 77 F-150 w/400 C6
Old Feb 28, 2003 | 12:01 AM
Boss_358's Avatar
Boss_358
jolt while driving
I'm trying to figure out what you mean by jolt. Could you maybe give a little more detail? When I think of the jolt when you hit the gas I am thinking maybe hesitation but am not sure with the deceleration.
Old Feb 28, 2003 | 12:08 AM
dbarracuda's Avatar
dbarracuda
jolt while driving
It almost seems like somthing that is spinning comes into contact with something not spinning or just not spinning as quickly. Does that help.
Old Feb 28, 2003 | 12:13 AM
Boss_358's Avatar
Boss_358
jolt while driving
Hmmm. Kind of a chattering or shudder? Does it make any noise or just a vibration?
Old Feb 28, 2003 | 08:37 AM
dbarracuda's Avatar
dbarracuda
jolt while driving
Its kinda like a clunk. It does not shudder or make any noise. Iwas thinking that maybe something had some play in it so that when you let off the gas somthing else would come arond and catchup with it. then you give it gas and it speeds back up and cathes the other part. I dont know this is just speculation of what it sounds like.
Thanks
David
Old Feb 28, 2003 | 09:48 AM
Boss_358's Avatar
Boss_358
jolt while driving
Have you checked your U-joints? Maybe the differential needs to be serviced and needs to be inspected for wear, chipped or broken teeth on the gears or anything else. Maybe the backlash just needs to be set in the ring and pinion. I would look towards this area and do a quick driveline inspection before tearing into anything or paying to have a shop look at something. Do a check and make sure everything seems tight and that there is no exsessive play at the pinion where the driveshaft hooks to the yoke. Make sure that yoke nut is tight as well. My parents had their van into a shop for a vibration and clunking sound a while ago. The so called mechanic said the tranny was fine and that they might need to have the rear axle fixed and that it could cost up to $600-$700. I looked at it and found that it just needed 2 new U-joints totalling $45. I just say this to beware because I just replied to message a week ago where someone was being taken for the same ride with a Bronco.
99F350bigorange
24
Apr 2, 2014 10:44 AM
mapsford5
Jul 17, 2013 09:42 AM
Tiggie
1983 - 2012 Ranger & B-Series
Aug 30, 2006 05:08 PM
ebexplorer1
Nov 26, 2005 04:08 PM
dbarracuda
Dec 20, 2001 11:52 AM
