jolt when accelerating
Old Dec 19, 2001 | 10:47 PM
dbarracuda's Avatar
dbarracuda
hey guys
I have this problem in my 77 F-150 400m. At least i think it is a problem. My gas pedal has a sticky spot in it and somtimes when i acceletate the pedal sticks. At that moment i feel a jolt as if some thing in the drive train is loose and is just now turning and coming into contact. When this happens i feel the gas pedal sink down a little. Any ideas of what this could be and is it serious.
thanks
David
Old Dec 19, 2001 | 10:52 PM
Mil1ion's Avatar
Mil1ion
Let's hope you still have TWO throttle return springs for one thing.
If one is missing or broken,that could cause an EASY pedal.
Does it do this in both 1st or 2nd gear from a full stop?
Sounds like a Transmission modulator to me,but I could be wrong.
Dennis:-X12
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles :-X12
Old Dec 20, 2001 | 08:02 AM
William's Avatar
William
Check your motor and transmission mounts.
William in Atlanta
Old Dec 20, 2001 | 08:28 AM
dbarracuda's Avatar
dbarracuda
Dennis
I believe that it only does this in first gear excep for the sticking. It will stick throughout all the gears. How do i tell if it is missing a spring?
Thanks
David
Old Dec 20, 2001 | 11:14 AM
beartracks's Avatar
beartracks
Follow Williams's advise. Have someone rev the motor in gear while you watch it to see if it rears up.
Bear
Old Dec 20, 2001 | 11:49 AM
73Custom's Avatar
73Custom
[font color=red size=2]A friend had a '78 that was sticking like that, we just sprayed the joints of the throttle linkage with lube and it stopped. When it was sticky, it would clunk too. Ended up it was just the jarring of the sudden acceleration and a little slack in the driveline. Check the driveline over for looseness or slack. I bet once you fix the sticky throttle, you won't notice a clunk anymore - try it out.
Marty
Old Dec 20, 2001 | 11:52 AM
ummduh's Avatar
ummduh
jmidd
Nov 15, 2017 06:40 AM
mapsford5
Jul 17, 2013 09:42 AM
96fonefitty
Jun 30, 2013 06:55 AM
arsenio11
Jun 27, 2013 08:43 AM
mayorphill
May 6, 2013 07:23 PM
