2bbl Choke adjustment
Old Nov 16, 2010 | 07:37 PM
mktsc's Avatar
mktsc
The engine had been off for about 16 hours and completely cold. The choke appears to be inoperable. I pulled the aircleaner assembly and found that there what appears to be about 3 hoses and one vacuum line not hooked up. I'm not sure what belongs at these locations.
Sorry for the crappy pics.
Back of Carb:
Front of Carb:
They appear to run to some plate between the carb and intake. I'm assuming coolant should be flowing through this plate?
-MK
Old Nov 16, 2010 | 07:41 PM
Nathan Plemons's Avatar
Nathan Plemons
I can't really tell from the picture, but it looks like that choke cap adjustment is way off. Somewhere on the cap should be a mark that corresponds to the marks on the housing.
Also seriously wouldn't hurt to spend about $12 on a carb rebuild kit and just go through the whole thing and clean up some of that gunk.
Old Nov 16, 2010 | 07:50 PM
mktsc's Avatar
mktsc
I fully plan on rebuilding it, but I'd like to get it sorted out before I completely dissassemble it.
The first two pictures are taken from between the open hood and the windshield and depict the back side of the carb nearest the firewall. The third picture is of the front of the carb.
Again, sorry for the crappy pictures, and thanks for the help.
-MK
Old Nov 16, 2010 | 07:56 PM
Nathan Plemons
I wouldn't worry about the plate for just now. The vacuum port you point to on the carb in your first picture isn't really a vacuum port. Really it's where your hot air choke is supposed to draw in it's air because it would be filtered, at least that is where I connected mine. If you're not using it, it is allowing unfiltered air to be sucked past the air filter and I would cap it.
Here is a thread from some time back where I was helping another user. It has some pictures of my hot air choke. https://www.ford-trucks.com/forums/9...me-please.html
'77 F100 Custom
Dec 6, 2016 09:01 AM
herdfan75
Dec 5, 2016 09:19 AM
yabadaba
May 15, 2016 10:29 AM
Heesman
Sep 5, 2014 03:00 PM
ATC_250SX
Jan 2, 2005 11:19 PM
