dana 35 problems
Old Nov 14, 2010 | 01:42 PM
justforkicks's Avatar
justforkicks
dana 35 problems
i need to change the whole right side axle shaft on my 91 ranger 4x4. i got the axle gutted down to the differential pretty much but i need to get the differential out to change the right side shaft. the problem is the pinch bolt on the left side of the diff. does the bolt need to be all the way out or just loosened to get the diff out?
Old Nov 14, 2010 | 10:43 PM
g_k50's Avatar
g_k50
is that the front axle or rear?
U-washer or C washer,
Old Nov 15, 2010 | 07:55 PM
reddog99's Avatar
reddog99
The Dana 35 is used in the front...
Old Nov 16, 2010 | 12:41 AM
g_k50's Avatar
g_k50
Just checking on the level of knowledge around the OP, doesn't the axle slide out when the c-clip is removed?
Old Nov 22, 2010 | 02:34 PM
justforkicks
i have the differential still on the axle housing. i looked at it and i've already started taking the axle housings off the truck. the right side had to come off anyway because the radius arm bushings are shot so it's really not a big deal. going to change all the bushings while everything is this far apart, along with that bad axleshaft
briangelc
Sep 26, 2012 03:40 PM
fordman19762003
2004 - 2008 F150
Jul 3, 2012 11:23 AM
firefighter1416
1997 - 2003 F150
Apr 27, 2010 09:04 PM
Ron Kelley
Oct 29, 2007 02:54 AM
88EB
1978 - 1996 Big Bronco
Oct 9, 2001 07:05 AM
