1999 power stroke engine heater
Old Nov 13, 2010 | 07:33 PM
Goodys's Avatar
Goodys
Where is the d#8n thing located. Would an inline lower radiator hose engine heater work?
Old Nov 13, 2010 | 07:47 PM
jdbrigance's Avatar
jdbrigance
4th Gear
On my e99 250 the plug is right behind a bumper opening on the driver side, very convenient. Element is in the block nearby, but that's not what you're asking, I think. I believe they are stock on almost all 7.3's -mine was bought in GA, but yours may have the cord removed or something. Those are available.
Old Nov 13, 2010 | 07:58 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Could be dealer added in '99. Best way to find it is to look at the oil filter housing and see if there is a fitting with a cord coming out of it. If so, follow the cord to find your plug.
If there is just a blank fitting with no cord, then you can install an OEM unit in that spot and run the plug where you like.
Hope this helps.
Old Nov 13, 2010 | 08:13 PM
Goodys's Avatar
Goodys
thanks that does help.
Old Nov 13, 2010 | 10:45 PM
Ponyboychris's Avatar
Ponyboychris
Lay under the driver's side of the engine and look straight up to the oil filter housing, you should see a red cord that comes out of the housing and goes forward to the bumper area. Look at this.
Old Nov 13, 2010 | 11:08 PM
Shake-N-Bake
Nice pic Chris! I tried to rep you but I have to spread it around first. (maybe the OP will pick this one up for me...)
Old Nov 13, 2010 | 11:22 PM
Ponyboychris
Here's another pic to help as well. The blackish cord in the middle of this photo is the cord that runs up front to the bumper.
Old Nov 14, 2010 | 07:42 AM
Goodys's Avatar
Goodys
cool pics, thanks
MxDad567
1997 - 2003 F150
Jan 1, 2014 10:15 PM
The67Beast
Jul 28, 2005 10:40 AM
tw
Jan 14, 2003 01:10 PM
RRL78
1978 - 1996 Big Bronco
Oct 17, 2000 12:10 PM
hotrodford_88
Aug 23, 2000 06:21 AM
