defroster only no other controls help
Old Nov 13, 2010 | 04:40 PM
blondiesdave's Avatar
blondiesdave
Question defroster only no other controls help
have problem with heater controls? worked fine last year but only get defrost now. only thing worked on this summer is front wheel bearing replacement. tryed pinching vac lines to hubs no change? anybody run into this problem? first time posting hope someone can help thanks
2001 f250 7.3 130000mi
Old Nov 13, 2010 | 04:55 PM
Ponyboychris's Avatar
Ponyboychris
Couple things come to mind. When you did your front wheel replacement, did you replace the yellow o-rings? They can fall apart and cause a vacuum leak. Also, trace the vacuum lines back to the canister and pump that sits behind the passenger battery.
info on the o-ring in the wheel hub area: Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Nov 13, 2010 | 08:53 PM
spunks00's Avatar
spunks00
welcome to FTE, most of the time the problem is with vacuum leak at the hubs, if you have checked that then you should probobly look for checking your vacuum pump, resivore, and lines. Then if your vacuum is ok then check the switch. let us know how it turns out
Old Nov 16, 2010 | 08:41 PM
blondiesdave
thanks for ideas. will check them out this weekend and let you knowwhat i find. thanks
Old Nov 17, 2010 | 07:38 AM
Battman76's Avatar
Battman76
if you plug both lines at the egr vacuum solenoid it will prob work. Just did it on my 02 F250 7.3. I bought the part for 28 bucks from autozone but it wasnt right, prob have to go to a dealer. But found another post on here that really helped me figure out that it was prob my egr vacuum solenoid.
Old Nov 17, 2010 | 08:02 AM
Battman76's Avatar
Battman76
Ok, scratch that, on the 7.3 it's called the ESOF vacuum solenoid. Nobody will know what your talking about if you refer to egr, thus the wrong part I have in hand. Here is the part 7C3Z9H465-A. But I'd make sure to test plugging the vac lines to see if you dash blows. Hope it helps. the part is 70 bucks from ford.
Old Nov 20, 2010 | 08:57 PM
blondiesdave
found broken line on front end. checked vac pump and have no vac at pump.my next move is new pump right?
Old Nov 20, 2010 | 09:50 PM
WilsonTaylor's Avatar
WilsonTaylor
I'd check fuses first.
Old Nov 20, 2010 | 09:56 PM
twags6's Avatar
twags6
Check the fuses, but if the pump was running constantly for a long time, its shot.
Copedawg
Aug 17, 2015 05:56 AM
Nice Work Truck
Apr 18, 2014 04:33 AM
wetzelrbt
Sep 3, 2012 08:48 PM
FishnDaddy
Jun 19, 2011 10:41 PM
