Location TPS 2008 E350?
Old Jan 7, 2014 | 08:30 AM
interstategar's Avatar
interstategar
I have a 2008 E350 with the 5.4L eng. I'm getting the WRENCH light on the panel and after reading about other Ford models, it could be the TPS sensor.
Does anyone know where its located on this vehicle? The symptom is when I press the gas pedal down the engine doesn't rev up at all.
(I haven't tried getting any codes yet, but in case it is the TPS I want to where it is)
Old Jan 7, 2014 | 10:22 AM
JWA's Avatar
JWA
Throttle Position Sensor is located on/by the throttle body.
Get the codes pulled ASAP because that dash icon probably triggers when a few other things are amiss too. A TPS fault will be shown in any DTC string you're able to retrieve.
Most likely it is the TPS and if so isn't a tough repair assuming you're somewhat adept at DIY wrenching.
If you're not aware FTE has a dedicated forum to the 5.4 V8's, you could post this same question there. Be advised though first question and reply you'll get is "what are the DTC's ?" Link: Modular V8 (4.6L, 5.4L) - Ford Truck Enthusiasts Forums
Old Jan 8, 2014 | 04:42 AM
Im50fast's Avatar
Im50fast
My 07 has no throttle cable and therefore no TPS.
Your 08 is likely the same. Go get the codes.
Old Jan 8, 2014 | 06:38 AM
JWA's Avatar
JWA
Was it model year '04 and later with the fly-by-wire throttle control?
deeplist
Apr 29, 2015 02:01 PM
1986OhioF150
Jan 28, 2015 08:58 PM
rondogw
Nov 21, 2010 12:16 PM
matt3763
Jan 17, 2005 06:49 AM
eakanator
Jun 4, 2002 07:03 AM
