Backup Light connection orphaned
Old Nov 12, 2010 | 02:57 PM
breton79's Avatar
breton79
So I have this connection here I can't figure out where it goes. When I short it with a bit of wire, the reverse lights come on. This is what I want, but only when the trans (auto, '79) is in reverse. I'm rehooking lights someone unhooked a long time ago. Anyone know where these leads are supposed to go from here? One is WHT/PNK, the other is BLK/RED. There are no obvious stray wires to hook it back to so I assume they're long gone.
Old Nov 12, 2010 | 03:11 PM
steponit's Avatar
steponit
The connection for the 78/79 NSS/BU lights looks different than that.
The connection is grey and it located in the middle of the firewall just below the cowl
I see a white and black wire in the image
Old Nov 12, 2010 | 03:21 PM
breton79's Avatar
breton79
Somebody could've changed things around, but it most definitely is the black/red wire going to the backup lamps. I just take the short out and the lights go out. I was tipped off in this thread, picture halfway down:
https://www.ford-trucks.com/forums/1...s-problem.html
It shows two individual wires going off this bit, but I don't know where.
Old Nov 12, 2010 | 03:31 PM
Blown 331's Avatar
Blown 331
I wonder if his truck used to be a 4 speed then? The back up light harness looks exactly like that on my 1977 4-speed.
Old Nov 12, 2010 | 04:41 PM
breton79's Avatar
breton79
Here's the VIN. Doesn't tell me much.. Never seen one like it in the VIN decoders either.
The funny thing is that I messed with the Neutral Safety Switch this morning, hooked it up actually because it had been burned by the exhaust and someone bypassed it. Easy to fix, but what I couldn't figure out is... The white wire going to the Backup Light Switch, which is part of the NSS, is powered. There are two white/pink wires spliced together into a connection inlet. The other side of that goes down to the BLS, but the splice comes over here I think to this little connector. I don't understand... What would make the most sense is that the black/red coming off the NSS go straight to the backup lamps, powered by the white/pink circuit being closed inside the BLS, and powering the lights directly. Instead it comes to this little doohicky confusing the mess out of me.
Old Nov 12, 2010 | 06:51 PM
breton79's Avatar
breton79
Multimeter says white/pink at NSS switch is the same as white/pink at the doohicky. Same for black/red. Same wires, on or off. It's like this is crying out to be a bypass or something, the connection is supposed to be made in the tranny switch. The lights would work if it were happening, but it's not... NSS must be busted. Still, what the heck is this connection. It's going to haunt me.
Old Nov 12, 2010 | 07:22 PM
steponit's Avatar
steponit
Perhaps the steering column or wiring harness has been replaced ?
Take a photo of the drivers side of the transmission for us
chollyb
Bronco II
Jan 25, 2013 11:38 PM
pepsiguy
Large Truck
Sep 14, 2011 06:50 PM
TIKT B8
Jun 17, 2010 12:37 PM
weldman
May 26, 2002 11:05 AM
