Sponsored by: Real Truck
Window scratches
Old Nov 11, 2010 | 12:38 PM
2006powerstroke90's Avatar
2006powerstroke90
Window scratches
My windows have bad scratches in the from going up and down and dirt in the tracks any way to remove them or lessen them?
thanks
Old Nov 11, 2010 | 12:56 PM
TEAM HARD's Avatar
TEAM HARD
replace the windows from a donor (junkyard truck) and learn how to use your garden hose.
Old Nov 11, 2010 | 01:16 PM
DIXIEDOG1's Avatar
DIXIEDOG1
You can polish them out, it's a pain but the results are very good. Eastwood has a kit for polisihing deep scratches out of glass
Glass Polishing Kit For Deep Scratches
Old Nov 11, 2010 | 02:38 PM
Ranger 620's Avatar
Ranger 620
Mine have the same thing and I was told it had nothing to do with not washing, but that the seals under the window were faulty from the factory and didn't create a tight enough seal. Although they won't cover any replacement. the guys at the dealership said that there was a service bulletin about it, but nothing that they were going to fix for free. Mine are pretty bad as well. Quite frustrating. I may see if I can find some from a bone yard. Great idea.
Old Nov 11, 2010 | 02:55 PM
redford's Avatar
redford
FTE Leadership Emeritus
06-5-8***SIDE GLASS SCRATCHED DUE TO COLLECTION OF DIRT/DEBRIS IN WARPED OUTER WINDOW BELTLINE MOLDING
TSB
06-5-8
Publication Date: March 3, 2006
FORD:
2005 Excursion
2005-2006 F-Super Duty
This article supersedes TSB 05-17-1 to update the vehicle model years.
ISSUE:
Some 2005-2006 F-Super Duty and 2005 Excursion vehicles may exhibit the outer window beltline molding warping around the lower window channel. The condition may be described as warped or loose outer window molding. There may be a pucker or gap between the window beltline molding and the window glass. This may result in dirt and debris collecting between the molding and the glass and scratching the side-window glass.
ACTION:
Use the following Service Procedure to replace the outer window beltline molding and adjust the molding flange.
SERVICE PROCEDURE
Lower the side door window completely.
Remove outside mirror.
Remove outer beltline molding by lifting it up away from the flange (Figure 1).
Figure 1 - Article 06-5-8
Raise side door glass completely.
Measure distance from inboard surface of the door beltline molding flange to outboard surface of the window glass (Figure 2). Distance from flange to glass should be between 5/8-3/4" (15.30-18.30 mm).
Figure 2 - Article 06-5-8
Lower glass completely.
Adjust the door molding flange to meet the 5/8-3/4" (15.30-18.30 mm) dimension. Do not adjust flange more than 3/4" (18.30 mm) away from the glass.
Install a new lower window beltline molding.
Reinstall mirror.
PART NUMBER PART NAME
F81Z-2521452-AA Molding (Right Hand)
F81Z-2521453-AA Molding (Left Hand)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
060508A 2005-2006 F-Super Duty/2005 Excursion: Replace The Window Beltline Molding Includes Time To Adjust Flange Non-Power Mirror One Door (Do Not Use With 17682C, 23943A, 23943AB) 0.4 Hr.
060508B 2005-2006 F-Super Duty/2005 Excursion: Replace The Window Beltline Molding Includes Time To Adjust Flange Non-Power Mirror Both Doors (Do Not Use With 17682C, 23943A, 23943AB) 0.6 Hr.
060508C 2005-2006 F-Super Duty/2005 Excursion: Replace The Window Beltline Molding Includes Time To Adjust Flange Power Mirror One Door (Do Not Use With 17682C, 23943A, 23943AB) 0.5 Hr.
06050 2005-2006 F-Super Duty/2005 Excursion: Replace The Window Beltline Molding Includes Time To Adjust Flange Power Mirror One Door (Do Not Use With 17682C, 23943A, 23943AB) 0.9 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
2521452 07
Old Nov 11, 2010 | 06:12 PM
i eat hybrids's Avatar
i eat hybrids
My truck has the same issue.. If i took it in, do you think theyd fix it?
Old Nov 11, 2010 | 06:23 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Dont waste your time with a polishing wheel. Ive used those several times, it would take a hour to polish out a 4" deep scratch, then you would have a distortion starting to show. Those work well on a light scratch or a rub mark but nothing that catches your fingernail. That was on the laminated windshield, the tempered door glass would take even longer. The junkyards windows are most likely scratched also, maybe not if you're lucky. Getting a new door from a local auto glass shop and installing it yourself wouldnt be too expensive and its not that hard to do.
Old Nov 11, 2010 | 08:49 PM
jc8825's Avatar
jc8825
RainX will help a little bit.
Old Nov 12, 2010 | 05:58 AM
2006powerstroke90
What about breaking them and calling the insurance company? Say some broke into the truck or it got vandalized?
Old Nov 12, 2010 | 07:17 AM
Ranger 620's Avatar
Ranger 620
Probably not the smartest decision by an adult, but I suppose it would work...if you're into insurance fraud.
Old Nov 12, 2010 | 07:20 AM
Ranger 620's Avatar
Ranger 620
I've tried to think of every possible solution as well, and have finally settled on just leaving as is, even though it sucks.
Old Nov 12, 2010 | 08:44 AM
BillyBob69's Avatar
BillyBob69
OOPs... I should read better. Just saw someone else already posted the Eastwood link.
Old Nov 12, 2010 | 08:56 AM
acf6's Avatar
acf6
Wow. Really?
Amicus
Jan 11, 2017 03:51 AM
05MilMachine
Feb 25, 2016 06:50 PM
Mickey J
Jul 13, 2010 09:31 PM
cdrmotorsports
Oct 23, 2009 10:02 PM
phoneman71
Nov 13, 2004 03:44 PM
