This look right?
Old Nov 11, 2010 | 03:02 PM
mabc926's Avatar
mabc926
Got it all done.
Here/s my custom 4$ TSC clutch pin
First started with this.....
It was a tight enough fit all I did was put some locktight on it and pressed in it.
Then next was my brass bushing, I don't think this one will crack
And ended it all off with a cotter pin..
And here it is all done and on the truck...
And the bad thing is after all that, and bleeding the air out again, the clutch peddle still feels loose.
Old Nov 11, 2010 | 05:48 PM
Otahyoni's Avatar
Otahyoni
With the brass bushing thats probably better than mine...
Old Nov 11, 2010 | 06:29 PM
starmilt's Avatar
starmilt
With the way that was worn, there is a good chance the pin and bushings on the pedal assembly is worn. I have had to change the whole bracket that holds the pedals out before.
Old Nov 11, 2010 | 06:35 PM
mabc926's Avatar
mabc926
Oh man, that job would suck to do, bet the whole dash has to come out.
mabc926
24
May 4, 2018 09:20 PM
mabc926
13
Jan 15, 2011 10:54 AM
mabc926
21
Nov 9, 2010 07:45 PM
mabc926
Oct 3, 2010 03:06 PM
mabc926
Apr 29, 2010 12:18 PM
