This look right?
Old Nov 10, 2010 | 03:58 PM
mabc926's Avatar
mabc926
This look right?
Still working on my loose clutch peddle, the throw out bearing only sits maybe a hairs with away from the teeth on the pressure plate.
So I got to checking under the dash, and I found this.......
Is that pin supposed to be worn half way through like that?
I know Chris told me to check a pin, but I don't know if this is he one he was talking about or not.
Old Nov 10, 2010 | 04:22 PM
starmilt's Avatar
starmilt
I think worn is the key word here. There should be no slack at all in it, and with that much it is lucky you can get it in gear at idle.
Old Nov 10, 2010 | 05:03 PM
tecgod13's Avatar
tecgod13
There is supposed to be a cheesy plastic bushing there. From what I've seen here, it always breaks or wears out leading to what you see there. One fix out there is to redo it with I think a heim joint that won't wear out like cheesy plastic bushing will.
I really ought to check mine at some point... hmmm
Old Nov 10, 2010 | 05:33 PM
Otahyoni's Avatar
Otahyoni
Yea, that's the pin. I don't really know where you get a replacement. The pin is spot welded into that short arm.
Here's what i did:
Removed the arm
Ground off the welds and punched the pin out.
Found a bolt that fit snugly (might be 7/16", i cant remember exactly)
Drilled the hole in the arm out to accept the new "pin" and spot welded it on
Drilled a small hole at the end to put the retainer clip through
Here;s how bad mine was:
Old Nov 10, 2010 | 05:55 PM
ah1988's Avatar
ah1988
would a worn out clutch be the cause of hard shifting into on 1 & 2 gear a auto tranny having problems with 1 & 2 gear ,the truck kind makes a clunk felling when shifting into those gears.
Old Nov 10, 2010 | 05:57 PM
Otahyoni's Avatar
Otahyoni
If you have an automatic transmission you dont have a clutch like this.... maybe i'm not understanding your question...
Old Nov 10, 2010 | 06:08 PM
ah1988's Avatar
ah1988
i was just wondering what could be wrong with the tranny it kinda clunks when it shifts into 1&2 gear thought automatics had clutches oops my bad i am still learning .
Old Nov 10, 2010 | 06:13 PM
johnboggs21's Avatar
johnboggs21
Autos do have clutches, but not the same as manual trannys
Old Nov 10, 2010 | 06:23 PM
Otahyoni's Avatar
Otahyoni
That's why i said "like this".
Autos have internal clutch packs. I don't know a whole lot about them, but i'd think it's possible that worn clutches or bands could cause a clunk...
Old Nov 10, 2010 | 07:07 PM
mabc926's Avatar
mabc926
Alright, I'll get to work on that now!
Thought it didn't look right, but I had to ask just to make sure.
And yes auto trans do have clutches, it's called a torque converter!
That might be whats wrong, but for your sake I sure hope not, doing that job would suck.
I had to take off a torque converter once, the bolts are on the back of the flexplate, and everyone of them where either rusted, or they rounded off when I tried getting them off.
And being on the back of the flexplate doesn't give you alot of room to work with.
Old Nov 10, 2010 | 07:15 PM
starmilt's Avatar
starmilt
The clutch pack on an auto is inside the tranny itself, but worn clutches will cause soft shifts as they will be slipping not hard shifts.
Old Nov 10, 2010 | 08:33 PM
Country_boy_2007's Avatar
Country_boy_2007
i know on the C6's you can adjust some of the bands, but usually a clunk is a worn rear end.
Old Nov 10, 2010 | 10:00 PM
oreocreaming's Avatar
oreocreaming
FORD Clutch Rod End PERMANENT Repair powerstroke too. : eBay Motors (item 250722851453 end time Nov-13-10 11:02:57 PST) theres the real "FIX" just make one yourself for 1/2 the money
Old Nov 11, 2010 | 07:26 AM
tecgod13's Avatar
tecgod13
Originally Posted by oreocreaming
yah thats what I was talking about, just too lazy too search.
And I agree, thats way too much money.
Old Nov 11, 2010 | 08:11 AM
JD_F250's Avatar
JD_F250
I took mine out, welded the hole completely solid, and redrilled it to be the same size as the pin it goes on. no more problems. ive gone through those cheap bushings like candy. not any more
