Persistant code P1316
Old Nov 9, 2010 | 04:55 PM
fixnair's Avatar
fixnair
Man I'm getting tired of fighting this! For over a year now I have had my check engine light on and now I have to get it smogged before the end of the month. (yes I live in California " the land of fruits and nuts and sometimes even the weather is a little queer")
I have done the following to try and remedy this:
Removed valve covers and inspect connections and wiring. No issues found
Fifty cent mod
Tightened all the capscrews under valve cover.
Remove valve covers and replace wire loom and gasket
replace injector drive module at which time I measured the resistance of the wiring between the IDM and each injector. All were within spec, 3.0 to 3.4 ohms.[*]Also checked all my grounds associated with the injector drive module. No issues there either.
I am still getting P1316 "injector drive module codes"
I can clear it, then drive less than a mile before it comes back on.
I hope somebody can help me clear this up, I've spent close to a thousand dollars to remedy this and I don't want to take it to the dealer.
Old Nov 9, 2010 | 07:06 PM
F350-6's Avatar
F350-6
I assume no running issues other than the code? Have you run a buzz test or KOEO test to see if any other codes show up?
Old Nov 9, 2010 | 09:35 PM
fixnair's Avatar
fixnair
I have had other codes in the past. I have been able to clear them though. Most of them because I did something wrong while working on the truck like failing to connect a connector or putting a hose on the wrong place. I did have a code relating to "IPR low" a few times. As far as drivability issues though, I have had none. It runs stong, pulls the grapevine @ 65 in 6th gear. Grapevine is a strech of I-5 with a 6% grade and probably 5 miles long and I weigh 13,000 pounds.
I have not done a buzz test. This AE is new to me and I have not learned how to do it.
Jesser02EX
15
Sep 13, 2013 01:51 PM
biblicaltruth
Jul 19, 2013 07:40 PM
joeyd61
29
Feb 28, 2012 11:26 AM
fixnair
Mar 12, 2011 07:21 PM
fixnair
Feb 20, 2011 08:22 PM
