P1211 Code
Old Nov 8, 2010 | 10:12 PM
Skooner's Avatar
Skooner
P1211 Code
Hey Gang- this is my first post. I just installed single shot Stage I injectors in my 2001 7.3 Powerstroke this weekend as well as rebuilt the turbo with the 1.0 exhaust housing and wicked wheel. I also had the chip reburnt with the new codes. The truck runs great- but I keep getting P1211 codes lighting up my Check Engine Light. I can clear the code and it will not come on again until I kill & restart the truck. The truck has never had any issues prior to these upgrades. Any help would be greatly appreciated.
Already had 4" exhaust, Stage II AFE Intake, and a DI Performance 6-Position chip.
Old Nov 8, 2010 | 10:28 PM
big poppa's Avatar
big poppa
Let me be the first to welcome you to FTE, glad to have yaa aboard. I don't have my code book handy but somebody will be by soon to help you...
Old Nov 8, 2010 | 10:58 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Skooner, I show a p1211 code to be: Injector control pressure higher/lower than desired ( crank or run ) I hope this helps.
Old Nov 8, 2010 | 11:23 PM
Stewart_H's Avatar
Stewart_H
A P1211 means your HPOP can't keep up with the demands of your tunes, which is weird because you said you just installed single shots.
Single shots take less oil to operate than the stock injectors, so the tunes shouldn't be calling for more oil than the HPOP can deliver.
Someone better versed in custom tunes will have to chime in.
Stewart
Old Nov 8, 2010 | 11:30 PM
Bob Taulbee
Duct Tape Tech.
Stewart
I think his problem is while cranking, He said he could clear the code and it would not return until he shut it off and restarted. I don't know if his tunes would come into play while cranking. Its over my head.
Old Nov 8, 2010 | 11:41 PM
Bob Taulbee
Duct Tape Tech.
Could it have a leaking O ring or a popet valve leaking? just thinkingout loud
Old Nov 9, 2010 | 02:00 AM
Stewart_H's Avatar
Stewart_H
Ah, good catch. Thanks Bob, I missed that.
Stewart
Old Nov 9, 2010 | 08:28 AM
Skooner's Avatar
Skooner
Thanks
Gents- thanks for the welcome and all of the feedback so far. It sounds like I need to check the o-ring or popet valve- I assume on the ICP?
I forgot to mention that I have installed an externally regulated fuel system- would I need to adjust the fuel pressure and would that possibly be causing the code?
Old Nov 9, 2010 | 08:47 AM
Bob Taulbee
Duct Tape Tech.
Skooned, The comment by me about the popet valve is just my guess. The popet is on the injectors ( each injector ) leaking injector O ring. I think if the truck runs out Ok, the code is set while cranking. A small oil leak at low pressure ( 500 psi and lower ) will lower the pressure enough to set the code. A small leak higher pressure will not effect the pressure as much. When looking for problems after a repair the first thing I do is go back and recheck my work. The fuel system shouldn't be an issue, two seperate systems. This is just my thoughts, others will chime in soon.
Old Nov 9, 2010 | 08:58 AM
Bob Taulbee
Duct Tape Tech.
Shooner, If you can get or have access to a sacnner ( AE or A snapon ) you can see the high pressure oil pressure at all engine speeds even while cranking. That would by your best bet.
Old Nov 9, 2010 | 11:25 AM
lhud's Avatar
lhud
The ICP is a simple pressure sensor on the oil rail on the driver's side head near the front of the engine.
There is no adjustment on this; if it is good, it is good, if it is bad, replace it.
A P1284 code indicates a failure of the ICP sensor.
Old Nov 9, 2010 | 03:57 PM
Skooner's Avatar
Skooner
Update
Updated Information: the Check Engine Light comes on immediately when the key is turned- before cranking the motor. I have used a live scanner while driving and all readings are within operating range. There seems to be something triggering the code when the key is turned. Again- If I clear the code with a scanner- it does not come back on while driving and all scanned readings are good- so the ICP snesor is good. I hope this helps...
Old Nov 9, 2010 | 05:21 PM
Stewart_H's Avatar
Stewart_H
Hmmm, I'd contact your tuner and see if he has any ideas.
Because there's nothing mechanical going on at the time it occurs (engine not cranking, just ignition being turned on), I'm thinking maybe a glitch in the custom tune, if that's even possible.
Stewart
Old Nov 9, 2010 | 06:35 PM
Bob Taulbee
Duct Tape Tech.
Can you disconnect the tuner just to see is the SES light comes on. you shouldn't need to try to start, just turn the ign on
bom
Jul 30, 2024 01:36 AM
sudsmcduff
Nov 14, 2015 06:10 PM
hiattk
Apr 26, 2013 11:40 AM
viperbluelx
16
Dec 5, 2008 12:45 PM
Fullcrew7.3
Mar 7, 2008 09:07 AM
