Any one replace their....
Old Nov 8, 2010 | 05:59 PM
bulla's Avatar
bulla
Any on have to replace their power steering pump. I can move the pulley shaft in and out about a half an inch and it's starting to make a ticking noise. Has anyone had this problem and how expensive is it? I 'm guessing this may be contributing to my belt squeal. Thanks guys I look forward to your responses.
Old Nov 8, 2010 | 06:12 PM
PaysonPSD's Avatar
PaysonPSD
This is another great write-up by camodown. How to replace your power steering pump. Post #20 is where he reposted the missing pics.
Old Nov 8, 2010 | 06:20 PM
nookiemonster55's Avatar
nookiemonster55
Yea not hard at all....even I did it... turns out I believe it isnt my pump, but my gear box...symptoms still unchanged.....oh well...
Old Nov 8, 2010 | 06:31 PM
bulla's Avatar
bulla
Gotta hate that . Do you remember how much it was?
Old Nov 8, 2010 | 06:59 PM
big poppa's Avatar
big poppa
With that kind of in and out movement it sounds like you found the culprit to your previous problems. If money's tight, local parts house but you know you can't put a price on OEM. PartsGuyEd would be able to assist yaa, good luck.
Old Nov 11, 2010 | 12:35 PM
bulla's Avatar
bulla
Ok guys you are probably getting tired of me talking about this ridiculous belt issue I'm having but I broke down and bought the oem belt from ford $80 bucks ouch! But guess the squealing has ceased . Thank you jeasus. That was driving me crazy. It turns out the oem belt seems to be a little thicker and it has alot more tension than the nappa belt. I made a mark on the tensioner with the nappa belt and the oem belt and there was quite a big difference and with my original belt the tensioner was bottomed out and without a load on the engine the belt was a gatorback and it was causing the tensioner to tap on itself. Correction on the slack in my powersteering pump it only moves about a 1/4 in. In and out no slack up and down. Question about the tensioner there are some marks on it is that to tell you if the belt is too loose. If your not sure what I'm talking about I'll try and post a pic if I can figure it out on my phone.
Old Nov 11, 2010 | 12:53 PM
Franko72's Avatar
Franko72
Molon Labe
Dave, the Napa belts are junk. I remember you asking if I had any trouble with mine at the gtg. Well I Just replaced it because of squeeling . That's two Napa belts so far. Never again.
Old Nov 11, 2010 | 01:07 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I agree the about the napa "house" belts, I have never had good luck with them. I have heard good things about the Gatorbacks from other members but I have never used one on this truck. I bit the bullet and went with OEM also, heck the original one went 80k and looked good but I replaced it anyway just cause.
Old Nov 11, 2010 | 02:02 PM
Ponyboychris's Avatar
Ponyboychris
I'm a happy Gatorback belt owner. Yes, they seem to be fine so far. It's been a year on my truck (approx 7000 miles).
Old Nov 11, 2010 | 02:59 PM
bulla's Avatar
bulla
Did you get yours fixed frank? I hope this is it for squealing from me about my belt! Ha ha
Old Nov 11, 2010 | 03:16 PM
hammer65's Avatar
hammer65
Me too. Jim
Old Nov 11, 2010 | 06:29 PM
big poppa's Avatar
big poppa
Knock on wood and prolly pushing it but I still have my stock belt on my truck, no fraying or cracking. 151,000 so far.
Old Nov 11, 2010 | 06:35 PM
plgebbia's Avatar
plgebbia
It is pretty normal to have a little in and out play in the pump. You just don't want any side to side play...
Old Nov 12, 2010 | 05:18 PM
Franko72's Avatar
Franko72
Molon Labe
Yes I did David. I bought a Gates belt from O' Rileys, so far so good.
DJRAAL
Feb 8, 2024 04:52 PM
BCHauler
1997 - 2003 F150
Jul 2, 2013 12:30 PM
longjohn
Apr 21, 2012 12:57 PM
bretts3504x4
Aug 28, 2006 05:21 PM
Big90250
Sep 6, 2004 05:26 PM
