Sponsored by: Real Truck
Battery saver relay replacement
Old Sep 22, 2014 | 12:45 PM
DJRAAL's Avatar
DJRAAL
Any one know where the Battery saver relay is located and how I can replace it?
Also where is the GEM located and how do I replace it?
Old Feb 8, 2024 | 02:51 PM
Tyler Tyler's Avatar
Tyler Tyler
1st Gear
Battery saver relay is in interior fuse panel to the left of brake pedal but faces the seat (pull the black/dark grey cover off of fuse panel) 2nd relay from top - relay usually has a yellow cover. The GEM is attached to the back of that same fuse panel.
Old Feb 8, 2024 | 04:52 PM
projectSHO89's Avatar
projectSHO89
Originally Posted by Tyler Tyler
Battery saver relay is in interior fuse panel to the left of brake pedal but faces the seat (pull the black/dark grey cover off of fuse panel) 2nd relay from top - relay usually has a yellow cover. The GEM is attached to the back of that same fuse panel. 2002 Ford F150 Owners Manual : Fuses and Relays Location and Diagram (youtube.com)
Let's see... A first timer posts a response to a 10 year old post from someone who hasn't posted in a long time and with information that probably doesn't apply to the original question.
Epic...
slomafarms
1997 - 2003 F150
Oct 31, 2011 11:59 AM
Virginia Squire
Aug 12, 2010 09:22 AM
Jake45
Aug 24, 2009 07:56 AM
Keith1984
Electrical Systems/Wiring
Jan 13, 2006 02:04 PM
Jim_1
1997 - 2003 F150
Aug 14, 2002 06:23 PM
