do i need the fuel heater?
Old Nov 19, 2010 | 04:17 PM
joelswork's Avatar
joelswork
Ok, update. 3 IH dealers didn't have it, but I could order 10 for $35! I'm gonna just JB it tonight while I have a few hours. Works great if I run out and start it every 3 hours......just a slow leak anyways
Old Nov 20, 2010 | 07:53 AM
steedracer's Avatar
steedracer
Trailering
Fuel leak
I have a fuel leak from my fuel heater but it isn't leaking from the outside of the plug. It is leaking from the inside where the metal terminal is under thr terminal cap is. Is there a O ring there that can be replaced or can I just fill it with some sealer of some type and plug the wire back on?
Old Nov 20, 2010 | 08:09 AM
joelswork's Avatar
joelswork
Well, being in the middle of no where and not being able to get the o-ring....I cleaned the area and filled it with jb weld yesterday. We'll see if it worked this morning (oh, and I just taped off the wire and secured it out of the way)
Old Nov 20, 2010 | 12:26 PM
91 Super Duty's Avatar
91 Super Duty
The short answer is Yes, there are actually 2 O-rings, 1 you could cal an inner that seal where you are leaking from insode the spade plug for the fuel heater, the other seals where the hole heater assembly mounts to the filter housing. If you follow this link it will give you pics that show you where the 2 O-ring are, I called Ford to order a new fuel heater and they said the price was $160.00 list, https://www.ford-trucks.com/forums/9...ixingit-2.html look at post 24. Just wish I knew what the fuel heater was there for.
Teamrope
Nov 25, 2015 07:14 AM
ExPACamper
May 9, 2015 08:23 PM
Speedjester
Jan 24, 2015 04:17 AM
4x4 Bart
44
Mar 7, 2014 12:39 PM
YoungFordAddict66
18
Jan 23, 2011 08:10 PM
