bypass filter
Old Nov 8, 2010 | 09:15 AM
smokersteve's Avatar
smokersteve
bypass filter
I wouold rather not tap into the composit oil filte cap and it is very thing, or buy the alluminum because of the price.
Can I tap into the side of the oil filter housing?
Old Nov 8, 2010 | 09:20 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I don't know of anyone else that has tried......if you want to be the first....let us know what and how you do it. Take photos and post....thanks!
Old Nov 8, 2010 | 10:03 AM
High Binder's Avatar
High Binder
I wouldn't, tapping into the side of a cylinder defeats the strenth of a cylinder and with the **** metal that these are made out of you're looking at crack city. Plastic cap is easily replaced if you muck it up where as the oil filter assy is a royal pain.
Old Nov 8, 2010 | 11:10 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You will also need a short piece of pipe if you do the top of the filter cap. And then wrap tthat with insulation to get readings in the winter. The pipe will act as a radiator and cool the oil. See my gallery for photo of the pipe.
Old Nov 8, 2010 | 11:45 AM
hubler13f's Avatar
hubler13f
I would think it would be darn near impossible to tap into the side of the canister because it is very thin and it is a curved surface. This combination would make it impossible to have good clean threads and even if you did get it threaded I am doubtful you would be able to get to seal.
Old Nov 8, 2010 | 09:13 PM
smokersteve
I decided to buy a cap. but cant find one for cheaper than $75.
I would rather not buy new for the price.
Old Nov 8, 2010 | 09:18 PM
patrickke's Avatar
patrickke
they have the caps on ebay I got mine with the fuel filter cap for 100
Old Nov 8, 2010 | 09:20 PM
smokersteve
Old Nov 8, 2010 | 10:20 PM
patrickke's Avatar
patrickke
FORD POWERSTROKE 6.0 BILLET OIL AND FUEL FILTER CAPS: eBay Motors (item 260683303035 end time Nov-24-10 14:09:32 PST)
Here is what I got, a couple months ago I paid 100 even but now its 130 which still isn't bad
Old Nov 9, 2010 | 06:16 AM
DSMMH's Avatar
DSMMH
Why don't you just use the oil pressure test port at the base of the oil cooler?
Old Nov 9, 2010 | 02:01 PM
smokersteve
Would that work? picture?
Thanks
Old Nov 10, 2010 | 07:05 AM
DSMMH's Avatar
DSMMH
Thanks
I have never used an oil bypass filter. I don't believe in them. I choose to change my filter every 5,000 miles and my oil and filter every 10,000 miles. But that's just me!
I installed an AMSOIL bypass filter on a friend's 4.3L V-6 GM diesel, who I told he did not need the filter. I removed the oil pressure sending unit. Purchased a short piece of pipe and a female T. Installed the pipe, T and sending unit then ran a line from the T to the bypass filter inlet. Took the filter outlet and ran it to the valve cover.
Go here: Powerstroke 6.0L Technical Intro Manual
Look at page 24, center picture. I would think that you could run the filter input from the "oil pressure test port" and put the filter outlet wherever you want (oil filler tube is easy to do).
Old Nov 10, 2010 | 09:56 AM
smokersteve
do you guys think this would be the same as buying the cap? no issues?
El_Rodney
May 10, 2009 07:52 PM
jmaskew
Apr 23, 2008 05:09 PM
jwhitetail
23
Nov 4, 2007 02:42 PM
numocystic_10
Oil & Lubrication
42
Jul 12, 2006 11:34 AM
WB9PRG
Mar 21, 2002 06:39 PM
