Confussed high idle
Old Nov 9, 2010 | 10:32 AM
Speedjester's Avatar
Speedjester
Confussed high idle
Well would like to ask something I find odd... on a cold morning I start the truck....(fires right up) and settles into a normal idle(around 650-700) after its Running for 30-40 seconds the high idle kicks in(1100).....Is this normal is it supposed to warm a bit before it goes to high idle....thanks again...
Old Nov 9, 2010 | 11:00 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You are fine.
Old Nov 9, 2010 | 05:31 PM
fatcowvtx's Avatar
fatcowvtx
my does that too. So do we still need a high idle mod?
Old Nov 9, 2010 | 05:40 PM
Frankenbiker's Avatar
Frankenbiker
Yes.
The cold-weather warm-up strategy only works when the oil temp is below 40 degrees or so.
The high-idle mod gets your engine RPMS up for whatever reason you choose; and extended idle-time (especially without daily "blow-outs") is damaging to the engine.
-blaine
Old Nov 9, 2010 | 08:13 PM
Speedjester
Does anyone know why it stays low rpm before it goes to high idle....I usually just hop in start it up....buckle up and drive away....Is this ok or. Should I let it warm up...
Old Nov 10, 2010 | 10:34 AM
Frankenbiker
You're fine. Don't worry about it.
-blaine
