Sponsored by: Innova
Preamp Outputs
Old Feb 26, 2003 | 07:31 PM
xxxcre10xxx's Avatar
xxxcre10xxx
Preamp Outputs
I am looking at a cd player. The standard one have 2volt preouts. For twenty dollars more I can get 4volt preouts. I am going to have to 500watt amps coming from it. How much better sound will I get with the 4volt preouts? If i get the 2volts then I can probably get the player off ebay for real cheap.
Old Feb 26, 2003 | 09:08 PM
rbraughn's Avatar
rbraughn
Preamp Outputs
Pay the extra 20 dollars and get the 4 volt Pre-outs.
Old Feb 26, 2003 | 09:22 PM
RBrendel's Avatar
RBrendel
Preamp Outputs
the headunit is the most important part of a system, spend the extra money. you should buy a headunit with a built in equalizer and crossover if your running subs. you get what you pay for, try to avoid ebay
Old Feb 26, 2003 | 10:15 PM
carlos694x4's Avatar
carlos694x4
Preamp Outputs
I agree.
get the 4V preouts, but you can find a good deck on Ebay, just know what you are looking for.
Like anything else, your system is only as good as the weakest link, so make sure you get some good quality speakers, and make sure the amps are of good quality, not swap meet specials, that claim they are 500watts, and actually push 500 watts of distortion. I used to install Car audio and security, and believe me the no names are not worth it.
Old Feb 27, 2003 | 08:49 AM
LincolnHayes's Avatar
LincolnHayes
Preamp Outputs
I agree with the 4V preouts, I would also recommed you get a deck with a non-fading output set of RCA that are used just for subs.
Good Luck
LH
bound4h
Jul 12, 2006 10:12 PM
awf-150
May 23, 2004 04:40 PM
1969Ford_360
Apr 13, 2003 11:34 AM
JasonZ
Dec 29, 1999 07:07 PM
