302 N 96 Ranger
Old Nov 7, 2010 | 12:13 AM
SportCustomWalt's Avatar
SportCustomWalt
302 N 96 Ranger
First can a 302 fit in a 96 Ranger? If so is there a kit or parts to buy? I have a 302 that i rebuilt but never found anything worth placeing it in. I now have a 96 3.0 that has lasted for 230,000 and wants to retire. So has anyone put a 302 in there Ranger, I be greatful for any info.
Walt
Old Nov 7, 2010 | 06:10 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is some reading material for you. Ford Ranger V-8 Engine Swap
Old Nov 7, 2010 | 06:54 AM
smalltrucker's Avatar
smalltrucker
Yep been done a lot of times with all kinds of different componations. It's usually the wiring that is the hard part if you are not electrically inclined (me).
Dave
Old Nov 7, 2010 | 07:15 AM
pawpaw's Avatar
pawpaw
You might also check out the "Franken Ranger", at Harwood Performace, they have a manual & other info, kits, ect, on how to do it & that is one neat job, on a sleeper, tire smoking Ranger!!!!
HPE 1997 Ford Ranger Splash V-8
Old Nov 7, 2010 | 08:08 AM
smalltrucker
I had almost forgotten about Matt. His truck ended up about three blocks from where I worked but was sadly really beaten down by then. His manual is based around the '93' wiring which seems to be pretty common. Most would also reccomend getting one of the Ford wiring manuals for the donor and one for your truck. Usually can pick them up on E-Bay for $7-10 each.
Dave
Old Nov 7, 2010 | 09:07 AM
Old93junk's Avatar
Old93junk
Wiring is a pain on later EFI Rangers, but the mechanical work of the swap is no worse than it is in early non EFI Rangers.
Old Nov 9, 2010 | 07:41 PM
thad4411's Avatar
thad4411
I think that we are in the same boat. I have a 302that i got out of a Mark VII,haven't put it in yet,but I will have to change the mounts,and bellhouseing to make it fit on my 96! and a few other minor things. anyway,Have fun and Good Luck!
Old Nov 9, 2010 | 09:26 PM
smalltrucker
Actually, with the '98-2000' Rangers, wiring is a snap. The Explorers and Rangers share the same 104 pin connections at the CPU and makes the wiring so easy. If doing a 4x4 swap (torson suspension), even the motor mounts work.
Dave
natesfords
Oct 17, 2009 11:04 AM
northeaster79
Aug 13, 2009 11:23 PM
96_Black5.0
Apr 21, 2007 09:48 AM
ranger-r
Engine Swaps
Jun 17, 2004 07:54 PM
rangersvt04
Apr 26, 2004 11:06 PM
