88 ranger swaps
Old Jun 13, 2004 | 10:56 PM
ranger-r's Avatar
ranger-r
88 ranger swaps
hey i have an 88 ranger. it has the 2.3l four banger with a 5spd.
i was planning on putting a 302 in it and i was wondering what would need to be done and what kind of problems i might run into?
also the 302 plan's not set in stone so i was curious what other swaps people do with this gen of rangers.
thanks a lot =P
Old Jun 13, 2004 | 11:19 PM
Matts72's Avatar
Matts72
the 302/351W swap is very popular, easy to do, and relatively cheap. if you work some deals, you can do it for $2500.
Old Jun 13, 2004 | 11:29 PM
ranger-r's Avatar
ranger-r
2500?
thats u.s? i live in canada =P. that still gives me a good idea of a price tho.
is that 2500 for a 302 or 351?
Old Jun 13, 2004 | 11:40 PM
psdpower's Avatar
psdpower
Ranger R, Advanced Adapters has everything you need for a 302 or 351 swap. They have a manual available that details the entire swap. I think they recommend a 2 inch body lift for clearance for the valve covers. If you don't want the body lift you'll have to modify the heater box on the passenger side firewall. Remember a 351 is taller then a 302 so you will need more clearance to make it work.
Old Jun 14, 2004 | 11:04 AM
loudfords's Avatar
loudfords
If you make motor mounts yourself and are pretty handy you can do the swap for far less than 2500. $500 canadian would be pretty reasonable to me.
Old Jun 14, 2004 | 03:58 PM
ranger-r's Avatar
ranger-r
handy
im not the handyest guy in the world but my nabor has told me that he'll help me out for the swap. hes a real handy guy to have around im know he can fab up some mounts plus i know he's done countless swaps =P
thanks a lot guys
Old Jun 14, 2004 | 09:49 PM
Matts72's Avatar
Matts72
thats only if you don't rebuild the motor, and you don't upgrade the rear diff. You'll still be set back by headers ($120) motor mounts ($60) and a tranny ($200) my prices are in USD.
Old Jun 15, 2004 | 11:23 AM
loudfords's Avatar
loudfords
I was only counting the cost of swap parts, like mounts & headers etc., not the engine & tranny. Also, I've read that Crown Vic motor mounts are pretty close to what you need, a Crown Vic rad should also work, Crown Vic oil pan will fit. Hmm, maybe I should up my $$ estimate, as you'll need to upgrade the 7.5" rear end to an 8.8" at some point if you put any kind of power to it. I was looking a couple years at this swap to drop a 351 in my Ranger, but I ended up needing the 351 in my F150 instead.
Old Jun 17, 2004 | 07:54 PM
gjfpilot's Avatar
gjfpilot
I put a 302 in my '86 Bronco II which had a 2.9L originally. I used an AOD with the Advance Adapters transfer case adapter. Let me know if you have questions or want to see pictures.
Grant
t_dickie
Engine Swaps
May 29, 2009 12:32 AM
Caleb1
Offroad & 4x4
May 27, 2009 10:40 PM
88stxRanger
1983 - 2012 Ranger & B-Series
Mar 8, 2007 11:14 PM
Matts72
Nov 13, 2003 02:01 PM
wildstall
Feb 15, 2000 12:33 PM
