Extra vacuum line on IWE system???
Old Nov 6, 2010 | 09:05 PM
magnet1's Avatar
magnet1
I just had ball joints installed on my truck. My friends shop mechanic found that I had a torn driveshaft boot, So I decided to put one on while he had it open. He called me back and said he found a vacuum line on the drivers side down by the driveshaft that went no where. He checked all over and there is no spot for it to be attached. He couldn't quite get in to see if there was one on the drivers side. He checked the whole 4wd system out and ran it through the paces; Everything works fine. Is this some kind of vent, Or should it be hooked to something? He said its not pulling vacuum at all.
Old Nov 7, 2010 | 06:29 AM
60DRB's Avatar
60DRB
Two lines (they are joined if they are the facory originals) come off the IWEs. The larger is the actual vacuum, and the smaller is a vent line for the IWE. Both sides are the same in that manner. For future reference:
https://www.ford-trucks.com/forums/836438-everything-you-wanted-to-know-about-the-iwe-system-and-then-some.html
The 4x4 system is both easy to trouble-shoot and repair. Your friends' mechanic should already know about this, as he's working on Ford trucks.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
Hunter_97
2004 - 2008 F150
Jan 26, 2017 05:51 PM
bbdano
2004 - 2008 F150
Mar 14, 2016 03:21 PM
Crewcab Turbo
Jun 8, 2011 08:19 PM
macius2004
Apr 4, 2005 06:02 PM
