302 vs. 289 heads
Old Nov 8, 2010 | 06:55 PM
Greyf100's Avatar
Greyf100
interesting...ty.
Old Nov 8, 2010 | 10:11 PM
pcmenten's Avatar
pcmenten
So I'm wondering what, if any, difference there is between the C6OE head and the C5AE head. I have a burette so I can 'cc' the head if anybody is curious.
My head does have a thermactor bump, so that might explain why there's a new casting number/part.
Old Nov 9, 2010 | 12:17 AM
BlueOvalRage's Avatar
BlueOvalRage
I think the Thermactor bump being added on the C6OE is it. I've got a set of each around here and that is the only difference that I see.
Old Nov 9, 2010 | 06:06 PM
Beanscoot's Avatar
Beanscoot
Pushrod slots were used up to 1967 for Hi Performance 289 heads (which you are unlikely to come across).
Old Nov 9, 2010 | 09:03 PM
xlt4wd90's Avatar
xlt4wd90
Aside from when the pushrod slots wearing out with age and you not being able to replace them, are there other disadvantages to them? Do the slots serve adequately as guides for the pushrods, even for high performance applications?
Old Nov 10, 2010 | 04:52 AM
Old Hickory's Avatar
Old Hickory
All 289 HiPos used the slot guides for alignment of the pushrods and had screw in studs
but no guide plates and they worked fine with a solid lifter cam. All of the early 289
302 heads had the same size small valves and ports which really restricted the engines.
Any serious power requirement needed much head modification. Back in the day both
Holman-Moody and Shelby American offered fully ported 289 heads with larger valves.
Today all these heads would also need to have hardened valve seats installed to
survive the unleaded gas.
Old Nov 11, 2010 | 12:39 PM
Beanscoot's Avatar
Beanscoot
I don't think the pushrod slots ever wear out.
bjarnold1
May 19, 2017 12:11 AM
choate
Ford Truck Parts for Sale
Feb 15, 2016 02:45 PM
BigRobK
19
Dec 9, 2015 05:44 AM
vol1966
Mar 6, 2011 01:34 AM
260falcon
Dec 16, 2005 02:27 PM
