289 Head Gasket Tab
Old May 15, 2017 | 11:41 PM
bjarnold1's Avatar
bjarnold1
289 Head Gasket Tab
I'm replacing the intake on my 289 and when I was cleaning the head surfaces I noticed the tab on the drivers side head gasket has a crack. Does it affect anything being the outside edge?
Old May 18, 2017 | 09:57 PM
baddad457's Avatar
baddad457
No, it shouldn't be a worry. That tab sticking out tells you the gasket is installed as it should be, with the front coolant ports blocked off to force coolant to go all the way back through the passages before migrating up to the heads.
Old May 18, 2017 | 10:04 PM
bjarnold1's Avatar
bjarnold1
This is the first time doing a intake on a Ford. Do the new intake gaskets have to hook over those tabs?
Old May 18, 2017 | 10:10 PM
baddad457's Avatar
baddad457
Oh, those tabs. Thought you were talking about the ones in the front of the heads. Yea, the gaskets hook over those, but make sure the gasket seals all around the ports. I use a thin film of RTV sealer around the coolant ports and a dab in the corners where the end seals and gaskets meet.
Old May 19, 2017 | 12:11 AM
bjarnold1's Avatar
bjarnold1
I made sure the gaskets were flush with the heads and the bolt holes/passages lined up. I used Permatex black on the cooling ports on the intake side of the gaskets and Gasgacinch on the head and intake sides as well
bsiebert
Nov 21, 2010 01:30 AM
Troyandchristie
1983 - 2012 Ranger & B-Series
Apr 17, 2006 08:26 PM
Rockershaft
Oct 1, 2005 11:38 PM
RichardMaerz69
Feb 18, 2004 03:07 PM
Sedric
Jul 8, 2002 10:34 PM
