1990 7.3l problems
Old Nov 11, 2010 | 02:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
what type glow plugs did you put in??
motorcraft/beru, i hope.
all other glow plugs are garbage and burn out within a few weeks of installation.
Old Nov 11, 2010 | 11:42 PM
ytlogger's Avatar
ytlogger
I have Bosch GP's in my truck at this time. They have been in for about a year with no troubles. The plugs I took out were also Bosch. Only two were dead and no swelling or any other problems. They were at least four years old. I know the Beru reputation and I have a set for next replacement, but I can't complain about Bosch.
Old Nov 11, 2010 | 11:45 PM
ytlogger's Avatar
ytlogger
Wait now, on second thought one of the plugs I replaced a year ago was an AC I think.
Old Nov 11, 2010 | 11:55 PM
wreckinball's Avatar
wreckinball
you know what a cdr is? if not, clean it out and get er done. if that doesnt work, you are in need of an injector or ip job, or both.
Old Nov 12, 2010 | 04:59 AM
fisheasy's Avatar
fisheasy
No do not know what a cdr is
Old Nov 12, 2010 | 10:05 AM
ytlogger's Avatar
ytlogger
Crankcase Depression Regulator. It is an emission control device that routes crankcase emissions, essentially oil vapour, to the intake and reburns them. It also separates oil from the vapour and returns it to the lubricating side of the engine either through a valve cover or the valley pan. It is designed to close under acceleration so that excess oil is not sucked into the intake and if it is faulty or very dirty it will not close. My '89 is equipped with an aftermarket turbo and the cdr looks like a salmon can and is mounted to the intake between the air cleaner and the turbo on the left side on the engine(as viewed from flywheel) and has a hose going to the left valve cover. Non-turbo engines drain to the valley pan.
Old Nov 12, 2010 | 10:16 AM
87crewdually's Avatar
87crewdually
#7 located back of intake inlet held on with (2) 5/16" bolts (1/2" wrench).
LEGEND:
1 – Fast Idle Solenoid
2 – Injection Pump
3 – Exhaust Emission Label
4 – Air Inlet
5 – Lifting Eye (3 places)
6 – Engine Wire Harness
7 – CDR Valve
8 – Fuel Return Nipple
9 – Glow Plugs
10 – Injection Nozzles
11 – High Pressure Fuel Injection Lines
12 – Coolant Temperature Sensing Unit
13 – Heater Return
Old Nov 12, 2010 | 11:45 AM
ytlogger's Avatar
ytlogger
87crewdually, great posts with very helpful diagrams.
Old Nov 13, 2010 | 10:43 AM
fisheasy's Avatar
fisheasy
after letting it run and smoke out. it actually quit smoking and started running fine again
Old Nov 13, 2010 | 10:53 AM
tjc transport
i ain't rite
good news. sounds like you had a sticking injector, and the diesel kleen disolved the gunk.
Old Nov 13, 2010 | 12:25 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Glad to hear it! Post another update in a week or month, hopefully that cleared it up.
TJC:
Did you mean an injector sticking open longer than it should, or not opening?
Cause an injector not opening wouldn't cause those issues, just crack a single line on your truck and drive around to find out. Power will be out a little and the sound will be funky but no smoke for sure, will rev just fine.
But sticking open makes plenty of sense
lol wreckinball
If NOT, how would he know what to clean? lol
Old Nov 13, 2010 | 03:31 PM
tjc transport
i ain't rite
i meant sticking partially open, or giving an improper spray pattern
Old Nov 23, 2010 | 04:13 PM
  #28
fisheasy's Avatar
fisheasy
update
the truck is still running fine
Old Nov 23, 2010 | 05:17 PM
  #29
HORSINROUND's Avatar
HORSINROUND
Just a thought, my first idi had sticky injectors but i didn't wanna drop the money since i was at college for new ones, long story short addin seafoam at every fillup took care of the problem, now i do it with my new one just to keep everything clean
Kingkong0192
13
Aug 20, 2016 03:52 PM
BigBlackF-250
24
May 5, 2016 11:02 AM
sunuvabug
Mar 30, 2015 06:55 PM
hairyboxnoogle
20
Aug 7, 2011 06:31 PM
TourqueRise
19
Aug 27, 2009 11:10 PM
